enable OPT_USE_AUTH
sbennell
enable OPT_USE_AUTH
Post by sbennell »
after i enable OPT_USE_AUTH i can not see any output on any camares
No Auth.jpg (67.35 KiB) Viewed 2917 times
PacoLM
Re: enable OPT_USE_AUTH
Post by PacoLM »
Maybe you need to logoff and logon again.
jbaiao
Post by jbaiao »
You need to put AUTH_RELAY under System as "none".
Restart ZM.
Thats all.
carda
Post by carda »
jbaiao wrote:You need to put AUTH_RELAY under System as "none".
Restart ZM.
Thats all.
That works for me also. Should I have that as none though? Why doesn't hashed work? I am running Ubuntu 12.04
Fatman
Post by Fatman »
@ jbaiao - I agree that is one fix, which worked for me right now, but what is probably more concerning is that this doesn't fix the issue, it is lowering the security of the system
