Hello forums.
I am sorry for the bump of my own thread but I have been backwards and forwards with this and made zero progress
I have read thread after thread until my eyes are sore and my head is pounding!
I have read about using card=77 in modprobe.conf and all sorts of various command-line tools, none of which have helped. The documentation that came with the card says I have to use "options bttv gbuffers=16 card=133,132,133,133" which I have (and at least then, I get an image as per the above post in xawtv / zoneminder).
Here is my lspci for what it's worth:-
00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub
00:01.0 PCI bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL PCI Express Root Port
00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 3 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 4 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03)
00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d3)
00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03)
00:1f.2 IDE interface: Intel Corporation 82801FR/FRW (ICH6R/ICH6RW) SATA Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: nVidia Corporation NV44 [GeForce 6200 TurboCache(TM)] (rev a1)
06:03.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11)
06:05.0 FireWire (IEEE 1394): Agere Systems FW322/323 (rev 61)
06:08.0 Ethernet controller: Intel Corporation 82562ET/EZ/GT/GZ - PRO/100 VE (LOM) Ethernet Controller (rev 01)
07:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
07:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
07:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
07:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
07:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
07:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
07:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
07:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
I have also tried to query the card using zmu -d /dev/video0 -q -v
Error, failed to enumerate standard 20: Success
Google does not help, I found no results to explain this (probably because it's a zoneminder command and not a standard linux command).
This was received regardless of if ZM was running or was stopped.
dmesg | grep bttv:
[ 5.202689] bttv: driver version 0.9.19 loaded
[ 5.202696] bttv: using 16 buffers with 2080k (520 pages) each for capture
[ 5.202762] bttv: Bt8xx card found (0).
[ 5.202786] bttv 0000:07:0c.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 5.202803] bttv0: Bt878 (rev 17) at 0000:07:0c.0, irq: 19, latency: 32, mmio: 0xbfa01000
[ 5.202832] bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 5.202867] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 5.202939] bttv0: tuner absent
[ 5.203082] bttv0: registered device video0
[ 5.203150] bttv0: registered device vbi0
[ 5.203176] bttv0: PLL: 28636363 => 35468950 .. ok
[ 5.228319] bttv: Bt8xx card found (1).
[ 5.228342] bttv 0000:07:0d.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 5.228356] bttv1: Bt878 (rev 17) at 0000:07:0d.0, irq: 18, latency: 32, mmio: 0xbfa03000
[ 5.228381] bttv1: using: Kodicom 4400R (master) [card=132,insmod option]
[ 5.228414] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 5.228491] bttv1: tuner absent
[ 5.228591] bttv1: registered device video1
[ 5.228657] bttv1: registered device vbi1
[ 5.228681] bttv1: PLL: 28636363 => 35468950 ..
[ 13.293039] bttv: Bt8xx card found (2).
[ 13.293074] bttv 0000:07:0e.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 13.293090] bttv2: Bt878 (rev 17) at 0000:07:0e.0, irq: 21, latency: 32, mmio: 0xbfa05000
[ 13.293119] bttv2: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 13.293169] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 13.293241] bttv2: tuner absent
[ 13.293358] bttv2: registered device video2
[ 13.293432] bttv2: registered device vbi2
[ 13.293465] bttv2: PLL: 28636363 => 35468950 .. ok
[ 21.355034] bttv: Bt8xx card found (3).
[ 21.355067] bttv 0000:07:0f.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 21.355081] bttv3: Bt878 (rev 17) at 0000:07:0f.0, irq: 22, latency: 32, mmio: 0xbfa07000
[ 21.355103] bttv3: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 21.355145] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 21.355209] bttv3: tuner absent
[ 21.355303] bttv3: registered device video3
[ 21.355379] bttv3: registered device vbi3
[ 21.355412] bttv3: PLL: 28636363 => 35468950 .. ok
System configuration is OpenSuSE12.1, Pentium 4 at 3GHZ Kernel, ZM installed as per guide -->
http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE (used the one-click installer).
Linux 3.1.10-1.9-desktop #1 SMP PREEMPT Thu Apr 5 18:48:38 UTC 2012 (4a97ec8) i686 i686 i386 GNU/Linux
