hello all,
i need help to configure my IP CAM!
model: Advance WB-IP03A
details:
Advance Profile 1 WB-IP03A JPEG / MJPEG PTZ Listen Talk
System Device ID, Alias, Firmware Version, Web UI, Wifi Active, Wifi SSID
Device Status Alarm Status, DDNS Status, UPNP Status
Network LED Network Lamp
Image Resolution, Brightness, Contrast, Orientation, Mode
PTZ Disable Presets, Preset on start, Center on start, , PTZ Speed Adjustments, Manual Movement, Patrol - Up, Patrol - Down, Patrol - Left, Patrol - Right
Alarm Motion Detect, Motion Sensitivity, Motion Compensation, Send Mail, Input Armed, HTTP Trigger, HTTP URL
IR IR LEDS - On, IR LEDS - Off
tilt full area : max 100°
pan full area : max 340°
how to configure a *.pm file for this ipcam model for a full functional ZM control ?
I'd already tried to modify panasonicip.pm but when I get the control mode page of my ip cam (working well in monitor view), controls on this page do not work !!
other problem:
(screenshot attached!)
when I change to "modect" mode, I can not change or create a new control area !! in youtube, I have seen a video where the image windows become "green" with 4 handle points to change detect area... I have juste 1 (one) point in upper-left corner of the image , but cannot move it !!
please help!!
