Unable to query card : "Error0"
badger_fruit
Post by badger_fruit »
I have four cameras connected to a Kodicom 4400R (http://www.zoneminder.com/wiki/index.php/Kodicom_4400r) PCI card, running on a P4 3GHZ with 1GB RAM, ZM v1.25.0 and OpenSuse12.1.
The cameras are all displaying the image OK in Greyscale but I can't seem to get them working in colour :(
I saw somewhere else on the forum that one can use the 'zmu' tool which should return info of the devices and that I should be able to use these to configure the correct palette. Unfortunately, when I try to use the command "zmu -d /dev/video0 -q", I get "error0"; if I change the command to "zmu -d /dev/video0 -q -v", I get a slightly different error, "Error, failed to enumerate standard 20: Success".
On the ZM Wiki, it states that if I add "chroma_agc=1" into my modprobe config, this may work ... well, I have done that, and it hasn't!
For reference, my entire modprobe configuration reads:
options bttv gbuffers=16 card=133,132,133,133 chroma_agc=1
... which is how it is shown in the Wiki I linked to above.
Please help!
