Cambozola Help
JonThompson
Cambozola Help
Post by JonThompson »
If I try and use Cambozola (I'm forcing it for everyone at the moment for testing), I get this error messages when it tries to load...
java.lang.ClassNotFoundException: com.charliemouse.cambozola.Viewer
This is using zm 1.20.1 and the cambozola.jar that is available on the zm downloads page.
What do I need to do to remedy this?
cordel
Post by cordel »
Have you installed the java plugin for your browser?
Type in your browser url
about:plugins
You will see Java(TM) Plug-in if you have it. Otherwise you need to download the plugin and install it.,
JonThompson
Java is installed and running. I most likely have cambozola misconfigured somehow.
I put the app it /var/www/html/ and gave executable prefs by anyone.
cordel
Post by cordel »
The file needs to be in the root for zm or one of it's subfolders. Then the path info needs to be set in options - tools. It should already be set to the root by just pointing to cambozola.jar and if you want to place it in a folder under root then would be something like /java/cambozola.jar.
Cheers,
Cordel
JonThompson
That took care of it. I was thinking that cambozola needed to be installed in relation to the zm apps.
Now, is there any way of speeding the video up that cambozola is streaming?
Has anyone thought about using Darwin Streaming Server to stream the data? It is open source (although not GPL compatible). It should be able to stream the data without modifying the DSS code as DSS is used by web servers for streaming. It also supports streaming MPEG4 natively.
cordel
Post by cordel »
That's all in the configuration tabs for High, Medium, and Low B/W (bandwidth).
As far as the streaming server it might be interesting to have as an option but zms is authinticated aganst so there are no streams without authintacation allowed (If you have Requires Authintication option checked) and it any runs when needed.
madmax
cambozola
Post by madmax »
I agree. A Faster alternative to cambozola would be great.
zoneminder
Site Admin
Post by zoneminder »
A dedicated lightweight ZM interface app is on the roadmap, but not imminent in the next couple of releases.
Phil
Mr.Ed
Post by Mr.Ed »
Hi there,
I'm a bit struggling myself with the Cambozola solution.
Some time ago i did not have my Cambozola (correctly) setup, so locally i only used streaming MPEG. I have some drivers installed for streaming MPEG so i did not need / want Cambozola.
Recently some friends reported some problems with viewing the camera's from my birds project. I checked, and indeed, browsers without native support for MPEG did only show frozen MPEG or a black screen all together. I then discovered that my pathname for Cambozola was incorrect. I set it up the correct way and my friends were helped with the Cambozola solution. I entered 0.2 to refresh non-streamed images and gave them this way 5 frames per second, sort of. Works fine...
But after that time i cannot get any MPEG streaming whatsoever. I got it on auto detection, got Cambozola rigged up, have MPEG streaming on local browser, but sill....... no more streaming MPEG.
Ideas, anybody?
Ed.
A Horse is a Horse, of course of course...
Hw:P4SDX(P4/2.4GHz)+1Gb RAM+160Mb SATA Hdd+4xHaupp.WinTV-Radio (BT878)+1xPV153+1xPCVC840K (All PAL)
Sw: FC3 (2.6.9-1.667) + KDE + ZM-1.20.1 (Yum) + Mozilla Firefox
cordel
Post by cordel »
If you turn mpeg off, cambozola will work. Currently it's one or the other. I have been meaning to go in and set an option so that both could be used dependant on the browser but haven't gotten around to it yet.
BTW, Awsome idea to put your spec's as part of your signature. Kudos
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
