I have tried these Remote Host Paths:
/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=75&maxfps=2&buffer=1000
/zm/index.php?view=watch&mid=1
After doing a bit of searching, these seem to be the only remote host paths that half way work.
I'm sure there could be a lot of other possibilities and there could be other issues I have not thought of.
If anyone has any pointers or examples of remote host paths that may work to connect these cams to the server, I would appreciate the input.
Log Errors:
socket_sendto( /tmp/zm/zms-990345s.sock ) failed: No such file or directory
Terminating, last frame sent time 1339186306.711191 secs more than maximum of 10.000000
Can't find process with command of 'zma -m 4'
'zmc -m 4' exited abnormally, exit status 255
Failed to pre-capture monitor 4 (0/1)
Unable to connect to camera
Can't connect to remote camera: Connection timed out
