I'm stumped ... this must be easy but I can't figure out how to do it.
I have a number of laptops on my home LAN, all of which have webcams built in.
What I want to do is stream all of them to Zoneminder which I have up and running on an Ubuntu machine on the LAN.
What I can't do is find a Windows webcam streamer which seems to integrate with Zoneminder.
Does anyone have a setup like this up and running? What software/settings do you recommend?
Thanks in advance
dannyboy
Monitor webcams on Windows PCs on my LAN
Re: Monitor webcams on Windows PCs on my LAN
Give VLC a try. As for setting it up I can't help.
Yes vlc certainly looks like the right tool for the job but I'm struggling with setting it up to provide a stream that ZoneMinder can recognise.
VideoLan.org is your best bet now. I believe I setup VLC on ZM box and got the VLC to VLC working first using jpeg as the output, then plugged the settings into ZM.
Sorted.
On the Windows PCs:
vlc dshow:// --sout "#transcode{vcodec=mp4v,vb=800,width=640,height=480,fps=10}:standard{access=http,mux=asf,dst=:8080}" --no-sout-audio -I dummy
On the Linux PCs:
cvlc v4l2:// --sout "#transcode{vcodec=mp4v,vb=800,width=640,height=480,fps=10}:standard{access=http,mux=asf,dst=:8080}" --no-sout-audio
Within Zoneminder, set the monitor source type to "Ffmpeg" and the source path to h-t-t-p://[ip address of PC running vlc]:8080
(without the dashes - this forum won't let me post what it thinks is a URL)
Hooray!
Now for a bit of optimisation of frame rates/quality etc.
On the Windows PCs:
On the Linux PCs:
Hooray!
Thanks, it looks like VLC is working perfectly because I can view stream with other video player like mplayer, but Zoneminder still doesn't see any video coming in
I edited shmmax and shmall and it should accept video images bigger than 320x200 because that is usuall issue with Zoneminder and cameras with 640x480 and higher resolutions.
I set these:
echo 536870912 >/proc/sys/kernel/shmall
Any other ideas why Zoneminder isn't seeing cameras?
I set these:
