Zoneminder Zone Configuration Zone Image gone
pete_c
Post by pete_c »
I've had no issues running Zoneminder 1.24.2 on Ubuntu 11.04 / 32 Bit until a couple of days ago when I noticed that the zone image was gone in the zone configuration screen. Everything else is there and ZM appears to be working fine.
I did do a "downsize" of all of the screens to 16:9 (640X480 to 640X368) a few days back.
Anyone ever see this?
Zoneminder User
Box #1 and # 2 - Intel Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Box #3 - AMD Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Moved rest of analogue cams to Axis Servers and Grandstream cams.
volbug
Re: Zoneminder Zone Configuration Zone Image gone
Post by volbug »
Did you ever solve this problem? My zone configuration image is also missing. Everything else works fine.
zSeries
Post by zSeries »
I just had this problem. Check the log for
Jan 31 19:22:03 host zmu[2168]: ERR [Can't open Zones4.jpg: Permission denied]
Jan 31 19:22:11 host zmu[2171]: ERR [Can't open Zones4.jpg: Permission denied]
The solution
sudo chown www-data:www-data events
sudo chown www-data:www-data images
sudo chown www-data:www-data temp
It may be because I mounted 3 seperate folders from on a separate hard disk partitions e.g. In /etc/fstab I have
/ext_hd/events /usr/share/zoneminder/events
I didn't look any deeper that that.
