Can't put simple quotes into mail message
dijitool
Post by dijitool »
Thanks for this really great software!
Just for information, I can't put simple quote like ' into the zoneminder mail message.
For exemple the text "l'evenement" return me :
SQL-ERR 'You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'evenement' where Name = 'ZM_EMAIL_BODY'' at line 1', statement was 'update Config set Value = 'l'evenement' where Name = 'ZM_EMAIL_BODY''
I've tried to put l\'evenement but it doesn't works.
usersenior
Re: Can't put simple quotes into mail message
Post by usersenior »
try so
l'evenement
