I have a camera that uses inbuilt motion detection (monitor number 20 on my setup). I have it set up to make a call to the zoneminder webserver to force an alarm when it detects motion using:
192.168.1.15/zm/index.php?view=request&request=alarm&id=20&command=forceAlarm
However, the camera doesn't have a way to make a call to the corresponding cancelForcedAlarm when the motion is over.
My question: Is their any way I can use HTTP to enable an alarm on my camera for a set length of time? (or tell ZM to start doing it's own motion detection and turn off the alarm when the motion ends?)
I know that zmtrigger.pl accepts telnet connections, but I'd like to use HTTP calls via the ZM webserver....
Thanks for any tips...
Jay
How to force an alarm via the web interface that turns off?
Re: How to force an alarm via the web interface that turns o
Bump....anybody?
Make a custom cgi script. I use cgi script like this one that my acti camera calls on camera based motion detection. Must have opt_triggers enabled in options. But this is using zmtrigger & "telnet"...
#!/bin/bash
echo Content-type: text/plain
echo "$1|on+10|255|AMotion" >/dev/tcp/localhost/6802
That's for the reply....I think I could get the camera to use zmtrigger directly, but I wanted to avoid having to start up another process and make sure it was running. I think you are pointing me in the right direction however. I can simply make a CGI script that the camera can call which will use wget to force an alarm via the web interface, and pause for X amount of time and then cancel the alarm... Or, perhaps I should just use zmtrigger...
