Hi Guys,
I'm setting up a system using v1.25 and have one Axis camera working well. I'd like to use the camera built into my Lenovo T500 (the zoneminder host computer) as a second Monitor. zmu shows that the camera support YUV 4:2:2 (YUYV) (YUYV) but I haven't found settings that work. The camera works perfectly with cheese. Can anyone help with the settings? I suspect the Device Format is what's whipping me but I'm not at all sure.
OS: Xubuntu 12.04
General Tab
Source Type: Local
Function: Monitor
Maximum FPS: 5
Reference Image Blend: 7
Source Tab
Device Path: /dev/video0
Capture Method: Video For Linux version 2
Device Channel: 0
Device Format: PAL
Capture Palette: YUYV
Capture Width: 320
Capture Height: 240
Thanks for any help....
