Hello guys,
Maybe some one can help me.
Since i deleted the 000-default file in /etc/apache2/sites-available/ is it no more possible to get the stream of the monitor into webinterface.
I try to reinstall zoneminder, it recreate the 000-default file, but still no stream.
When i open one event and of this monitor, i get the picture.
Same if i will retrace the zone for this monitor, i got the picture, but no possibility getting the online stream from the cam.
I try to reinstall apache2 without succes, same i make with zoneminder without succes too.
I try to configure zoneminder again, witouht succes, still the same problem, all is ok, but not the stream. I change the ownerchip for cambozola, try a newer version of cambozola,.... nothing change.
Maybe anyone know whats the problem.
I try Firefox and IE, still the same
Thanks a lot for reply and trying to help me
Best Regards
Monitor Stream doesn't work
Re: Monitor Stream doesn't work
Anything in the logs?
Hello, Thanks for reply
Witch log i shoud control?
zmwatchdog, seems to write nothing, and i check 2 other log files, i found nothing.
Apache's logs first. /var/log/apache/error_log is debian's place. Also access_log
Then syslog, and you may need to turn logging on in zm's console.
OK Thanks
That's what i get from apache2/errorlog
[Fri Aug 31 10:36:52 2012] [error] [client x.x.x.x] ERR [socket_sendto( /tmp/zm/zms-881013s.sock ) failed: No such file or directory], referer: htp://zmserver/zm/index.php?view=watch&mid=7
Acceslog
x.x.x.x - - [29/Aug/2012:10:46:05 +0200] "GET /DC HTP/1.1" 404 496 "-" "Mozilla/5.0 (Windows NT 6.1; rv:14.0) Gecko/20100101 Firefox/14.0.1"
Nothing for Aug 31
Acceslog
Nothing for Aug 31
Someone can help me
I know this is not the right topic, but have not found a suitable
In my Zoneminder he is not recording any event modect mode, and therefore no file is saved
I do not know what's happening
