I have a 250GB drive mounted on /media/storage. I have this running on CentOS 6.3.
Created the following dirs:
/media/storage/zm/events
/media/storage/zm/images
in /var/www/html/zm I did:
ln -s /media/storage/zm/events events
ln -s /media/storage/zm/images images
Its looks like this:
0 lrwxrwxrwx 1 root root 24 Sep 11 18:49 events -> /media/storage/zm/events
0 lrwxrwxrwx 1 root root 24 Sep 11 18:49 images -> /media/storage/zm/images
Also, disk space is -1% when I log into ZM. I have 218GB free actually.
I've went to ZM and set paths to absoloute and also as just "images" and "events", neither work. ZM constantly "records" events, they are always blank.
Any fixes to this annoying problem that quite a few people have ?
Moving 'events' and 'images' to another drive breaks ZM
Re: Moving 'events' and 'images' to another drive breaks ZM
Try chmod to www-data both folders.
you mean chown.
No, I dont have that www-data user for one, second, its 777 which means anyone can rwx.
Had I spent more time with the SEARCH feature, I would have found my answer. LOL.
You have to bind-mount it..
http://www.zoneminder.com/wiki/index.ph ... Hard_Drive
my original setup in fstab with cruft removed:
/dev/sdb2 /media/storage ext4 defaults
I added:
/media/storage/zm/events /var/www/html/zm/events none defaults,bind 0 2
/media/storage/zm/images /var/www/html/zm/images none defaults,bind 0 2
The "/var/www/...." that is where my current images/events resides. Once you mount the last two lines, it automagically works with ZM and disk space is reported correctly.
Problem solved.
I added:
Problem solved.
