Hello once again.
I'm having trouble with MPEG generation. The encoder apparently is only taking the first page (from the frame by frame view) of JPEGs when encoding it into a MPEG file.
Is there a setting I am missing that will allow it to use all of the frames in the MPEG file?
MPEG Generation cuts short
- zoneminder
- Site Admin
- Contact:
Are you talking about the static mpeg file generation (rather than the etsreaming)? If so do you see any errors in zmvideo.log? People have reported that newer versions of ffmpeg are rather miserly about what frame rates they allow whereas 0.4.8 seems to be a lot more flexible. You can always use zmvideo.pl directly if you want to investigate this a little more without needing to get involved with the web interface.
Phil
Phil
- zoneminder
- Site Admin
- Contact:
Video generation is very much in the hands of which version of ffmpeg you have installed. Is there anything odd in zmvideo.log?
If you hit problems like this, the best thing is sometimes to try and manually try and generate a file using ffmpeg and then to edit the ZM options to ensure that the same options are passed in. If you can't do it manualy with a particular set of options then it's unlikely that ZM will be able to do it automatically.
Phil
Phil
OK, here's the problem...
If I manually use this command...
sudo /usr/local/bin/ffmpeg -y -hq -intra -r 20.89 -s 640x320 -i *-capture.jpg Event-1.mpg
it gives me this...
001-capture.jpg: Unknown format
If I manually use this command (which ZM is automating)...
sudo /usr/local/bin/ffmpeg -y -hq -intra -r 20.89 -s 640x320 -i %03d-capture.jpg Event-1.mpg
mjpeg: JFIF header found (version: 1.1)
Input #0, image, from '%03d-capture.jpg':
Duration: 00:00:01.9, bitrate: N/A
Stream #0.0: Video: rawvideo, yuvj420p, 640x320, 20.89 fps
Output #0, mpeg, to 'Event-1.mpg':
Stream #0.0: Video: mpeg1video (hq), 640x320, 20.89 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
frame= 6 q=25.0 size= 42kB time=0.3 bitrate=1197.9kbits/s
Now, what is '%03d' and why does * not work in its place? Why is '%03d' only using 6 pictures when it attempts to encode.
it gives me this...
Stream mapping:
Stream #0.0 -> #0.0
OK, just needed to google it...
%03d will generate 3 digit numbers starting with 001 in ffmpeg. Unfortunately, zm generates 3 digit numbers until it is a 4 digit number, which means it is impossible to create a mpeg from 3238 jpegs or even 1000 jpegs without changing the mpeg line to %04d and changing all files <1000 to a 4 digit number.
- zoneminder
- Site Admin
- Contact:
