Can I use a different web server with zoneminder, ie. using mini-httpd instead of apache? if yes how would I go about configuring it?
Thank you
New user question...
Re: New user question...
Yes you can, all you have to do is enable php and create an alias to your zm web directory. I am sure you can find a forum for the server daemon you are looking at running. You have to do the following:
Allow following of symbolic links
enable php
add index.php to the list of index's
Create a directory alias for your zm web directory
Create a script alias for cgi-bin
And with a bit of tweaking you should be up. The steps are going to vary between the different web servers out there, you should check their documentation
enable php
