FC3 zm-1.21.0 RPM is up for test
zoneminder
Site Admin
Post by zoneminder »
I'll take a look at the http refresh issue.
Phil
JimNoble
Post by JimNoble »
I have 1.21 installed and working a treat now (thanks cordel!).
cpu usage is down from ~100% to about 10% (1 local @15fps, 1 remote @ 2fps) incidentally! Not quite sure what was going on there. The cpu runs 10C cooler now though :)
What kernel versions are people usingwith the fc3 rpms? I might need to upgrade to 2.6.10-1.770 from 2.6.9-1.667 and it would be nice to know it won't break anything...
Jim
cordel
Post by cordel »
I'm running the latest now with out any issues. At some point drivers were also added for the apacer intern memory card reader (nice suprise).
reza
can't download it
Post by reza »
it says that i'm not authorized for that section then redirects me to the homepage. Can you re-upload the file or fix the permissions?
thanks,
Reza
p.s. i've got fc3 and updates to some lib broke it - will this rmp fix that problem?
cordel
Post by cordel »
All links have been fixed and I added Perl Module packages in the downloads section.
Sorry I have a few services that requires you to login and accidenly had this selected as one of them. Anonymous access to the downloads is now permited.
Regards,
Cordel
