[root@localhost LambNet]# service zm start
ERROR 1146 (42S02) at line 1: Table 'zm.Config' doesn't exist
Starting ZoneMinder: DBD::mysql::st execute failed: Table 'zm.Config' doesn't exist at /usr/local/share/perl5/ZoneMinder/Config.pm line 92.
Can't execute: Table 'zm.Config' doesn't exist at /usr/local/share/perl5/ZoneMinder/Config.pm line 100
BEGIN failed--compilation aborted at /usr/local/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/local/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/local/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 37.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 37.
[FAILED]
Have you installed the zoneminder from repositories or compiled yourself?
Anyway, download and extract the attached file and run the following commands in order to create the database for ZM1.25:
#create db
mysqladmin -u root -p -f drop zm
mysql -u root -p < db/zm_create.sql
#Password that is requested is Mysql root password that was entered during install, not your debian password.
mysql -u root -p
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
quit
mysqladmin -p reload
Don't forget to change 'zmuser' and 'zmpass' according to your settings.
#create db
mysql -u root -p
quit
Hope it helps,
PacoLM
Paco
Thank you so much for your help, wasn't quite as easy as your post made it look but i got their in the end
Just trying to figure out how to secure Zoneminder now
