Time Delta starts at Pre-Event start rather than at Alarm
bluejay
Post by bluejay »
I have been using an older release (1.22.3) and just recently that box crashed. So, I installed the newer 1.25 version.
With the newer version, I noticed that the Frames, Time Deltas now start at the 1st Pre-Event frame rather than the 1st Frame of the Alarm Event, like the older version did (1.22.3).
Specifically, I am triggering the start of the "event" using zmtrigger.pl.
Any idea why this changed and/or if there's a configuration to get this to work properly (like in 1.22.3)?
See attachments for the two comparisons in the time delta reporting.
Thanks for any help and/or information regarding this,
J.J.
ZM 1.25 Frames incorrectly showing the start of the first Pre-Event as 0.00 Time Delta, rather than the first frame of the actual Alarm as Time Delta 0.00.
ZM 1.22.3 Frames correctly showing the start of the alarm (within the total event) as 0.00 Time Delta.  Pre-Event frames are negative (as expected).
bluejay
Re: Time Delta starts at Pre-Event start rather than at Alar
Post by bluejay »
I guess a workaround solution to this is problem would be to post-process the Frames Table in the zm DB to recalculate the Delta after an Event completes.
Anyone have any idea how to fix this in the code and/or where it might be messing up?
Thanks for any help,
J.J.
tweedle_dumb
Post by tweedle_dumb »
We had the exact same problem and couldn't figure out a way to fix it in the software itself so we wrote a trigger to basically do what you suggested. Here is the code if you'd like to use it in your environment:
USE zm;
DELIMITER $$
CREATE
DEFINER = 'zmuser'@'%'
TRIGGER update_endTime
AFTER UPDATE
ON Events
FOR EACH ROW
BEGIN
  DECLARE inEventId   INT(10);
  DECLARE refDelta    DECIMAL(8, 2);
  DECLARE refFrameId  INT(10);
  DECLARE endTimeBool BOOLEAN;
  SET inEventId = NEW.Id;
  SELECT min(FrameId) FROM Frames WHERE Type = 'Alarm' AND EventId = inEventId INTO refFrameId;
  SELECT count(*) FROM  Events WHERE Id = inEventId AND EndTime IS NOT NULL INTO endTimeBool;
  IF endTimeBool > 0 THEN
    SELECT Delta FROM Frames WHERE EventId = inEventId AND FrameId = refFrameId INTO refDelta;
    IF refDelta <> 0 THEN
      UPDATE Frames SET Delta = Delta - refDelta WHERE EventId = inEventId;
    END IF;
  END IF;
END
DELIMITER ;
