The RPM only works with ffmpeg 0.4.8 since that is what I'm running. Eventualy I hope to make a screaming demon server that can run various configurations and distrobutions at the same time to make packages but I need to find someone that can get me the parts (mainboard, the two processors, and a couple hard drives at least) at OEM prices and/or get enough donations to afford it. The way things are going at the moment that will be at least 6 months out.
Regards,
Cordel
is there any desire to port the code so it works with the newer version 0.4.9? I dont mind working on it, but I just dont want to be duplicating any effort that's already underway. I actually saw a post that was takling about a zm that's compatible with the cvs version of ffmepg, but I never saw anything after the initial mention of it.
thnx,
reza
p.s. i need to use the newer version of ffmpeg as i run mythtv on the same box and it needs those libs.
I had been reconfiguring my current build machine back and forth to produce both versions but since the cvs version was not making video for saved events and as of lately my job has been keeping me 10 to 16 hours a day I decided that I didn't want to risk tring to keep track of what I have setup and breaking things all together.
I haven't kept track of where ffmpeg is on the cvs version to see if there is a way to produce video from jpeg at the lower 1-15 fps yet. Once ffmpeg is able to accomidate that I will make more of an effort.
Regards,
Cordel
