Change Directory of Images
kamil
Post by kamil »
Hi. Good day.. can I ask if i can save the images recorded by zoneminder to other partition? can you help me how to do that? Thank you very much.
I tried to make a link named events in /var/www/zm that leads to the other partition where i will save the images. But when I restart the zoneminder.. the symbolink link i made was replaced by the folder events. What I have done wrong. Thanks for the help. :)
Regards,
Kamil.
theforce
Re: Change Directory of Images
Post by theforce »
Dont use the symbolic links. Use your fstab to put them where you want. Its much better.
http://www.zoneminder.com/wiki/index.ph ... Hard_Drive
kamil
Post by kamil »
Happy New Year. :) I tried the fstab but i can't it did not work. I cant understand so I copy the codes and paste it on fstab. I replace "otherdrive" to my other partition but sadly.. it didnt work. can someone help me how to use the fstab correctly to change the path of the events and images. Thank you.
Regards,
Kamil
