As at 31-Dec-2012, using the zoneminder ebuild located in the overlay ''zugaina'', zoneminder does not compile on 64 bit (amd64) Gentoo with kernel 3.6.11 and GCC 4.6.3 p1.8
A solution was suggested that [http://www.linuxquestions.org/questions ... nt-939357/ in this forum post], however, I found that the patches, as supplied, did not work.
Suggestions welcomed.
[Solved] Does not compile plus PHP standards in classic skin
...Lyall
Re: Does not compile with GCC 4.6
Can you be a bit more informative? Please post some output from the compilation and your configure options etc (if you can pull it out of the ebuild?)
I can do more than that.
The following patch, when integrated into the 1.25.0 zugaina www-misc/zoneminder ebuild, fixes the problem.
--- src/zm_local_camera.cpp~ 2012-09-11 12:41:09.711153916 +0100
+++ src/zm_local_camera.cpp 2012-09-11 12:41:09.725153941 +0100
@@ -1048,7 +1048,8 @@
Debug( 3, "Terminating video stream" );
//enum v4l2_buf_type type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
- enum v4l2_buf_type type = v4l2_data.fmt.type;
+ // enum v4l2_buf_type type = v4l2_data.fmt.type;
+ enum v4l2_buf_type type = (v4l2_buf_type)v4l2_data.fmt.type;
if ( vidioctl( vid_fd, VIDIOC_STREAMOFF, &type ) < 0 )
Error( "Failed to stop capture stream: %s", strerror(errno) );
@@ -1931,7 +1932,8 @@
Debug( 3, "Starting video stream" );
if ( vidioctl( vid_fd, VIDIOC_STREAMON, &type ) < 0 )
Fatal( "Failed to start capture stream: %s", strerror(errno) );
...Lyall
Here is another patch to correct a warning from the classic skin.
I have not checked to see if something similar needs to be done to the other skins.
--- web/skins/classic/views/event.php~ 2010-11-04 02:19:47.000000000 +1030
+++ web/skins/classic/views/event.php 2013-01-01 16:06:43.000000000 +1030
@@ -59,8 +59,13 @@
$replayMode = validHtmlStr($_REQUEST['replayMode']);
if ( isset( $_COOKIE['replayMode']) && preg_match('#^[a-z]+$#', $_COOKIE['replayMode']) )
$replayMode = validHtmlStr($_COOKIE['replayMode']);
- else
- $replayMode = array_shift( array_keys( $replayModes ) );
+ else {
+ $holdingVar = array_keys( $replayModes );
+ $replayMode = array_shift( $holdingVar );
+ // $replayMode = array_shift( array_keys( $replayModes ) );
+ unset( $holdingVar );
parseSort();
parseFilter( $_REQUEST['filter'] );
...Lyall
