I have seen topics about the socket_sendto ... no such file or directory... problem, and I have also seen solutions, but for some reason the solutions do not work for me.
Everything works fine if I go to ZM in my internal network. However, if I try to see my camera image from the internet, the above error messages reappear, and I get a Cambozola classnotfoundexception.
One solution mentions an issue with cgi-bin where the standard cgi-bin in httpd.conf is being changed to the cgi-bin in the zoneminder tree.
I have ZM 1.25 (on CentOS 6.3, 64bit) and there is no cgi-bin in the zm tree which is in /var/www/html. The two programs (nph-zms and zms) are in the standard cgi-bin directory.
The issue seems to only appear when I go to ZM via the internet, not when I go directly to the linux server.
Could this be a firewall issue ? I'm only using ports 80 and 443. Both are open in my firewall.
I'm a bit confused and don't know where to look anymore.
Can anyone please help me out ?
Thanks,
Hans
Still having socket_sendto problems
Re: Still having socket_sendto problems
Anyone, please ?
My problem was using port 78 instead of 80 on apache. As soon as i reverted to 80 the problem was fixed. However, i am not sure why this was as i am no apache expert, or even proficient with apache for that matter.
Hope this helps
Hope this helps
SELinux or firewall issue maybe?
Hi Axel,
Thanks for answering.
Nope. Disabled SELINUX and stopped both iptables and ip6tables, as per instructions....
(and rebooted..)
(and rebooted..)
