unable to move or add zone nodes
pk2k
Post by pk2k »
When attempting to create a new zone the top LH node is the only node visable and the node can not be selected or moved. there is no means to create a new node.
can not edit the window by clicking on it.
pk2k
Re: unable to move or add zone nodes
Post by pk2k »
bump, have tested this in Internet explorer and Mozilla still unable to create a zone except one that fills the whole screen, can not resize a zone either.
pk2k
Post by pk2k »
Not sure if this is an associated problem but Montage view does not work either, all windows remain "stacked " regardless of the Montage setting selected.
Java problem perhaps?
jameswilson
Post by jameswilson »
Never had this myself. Firefox is the best browser to use. I do recall some time ago having to click on the 'node' and then click where you wanted it rather than dragging if thats any help
James Wilson
pk2k
Post by pk2k »
Sorry, This did not help, there is still only one node visable when creating new or editing existing zones and this cannot be moved.
there are also no coords under the points x, y section either.
all newly created zones can only be full screen.
Is this a java or charliemouse prob?
any suggestions welcome :(
capture of zone edit screen
tsy
Post by tsy »
My case seems to be the same.
In my case, there are the syslog messages like follows,
web_php[4531]: ERR [Uncaught TypeError: Object #<HTMLDivElement> has no method 'makeDraggable']
web_php[4531]: ERR [Uncaught TypeError: Cannot call method 'addClass' of null]
web_php[4531]: ERR [Uncaught TypeError: Cannot call method 'removeClass' of null]
Where should I check around other than skins/classic/includes/functions.php and /usr/share/javascript/mootools/mootools-{mc}ore-nc.js ?
PacoLM
Post by PacoLM »
Take a look to this post, http://www.zoneminder.com/forums/viewto ... t=mootools
Hope it helps,
PacoLM
tsy
Post by tsy »
Thank you for your advice PacoLM,
In my case, the path settings to mootools were O.K.
For me, "mootools-1.2.5.1-more.js" from mootools.\net worked!!
I tried "mootools-core-1.4.5-full-compat.js" and "mootools-core-1.3.2-full-compat.js" with it, and they both work fine. The montage layouts work with them too.
"mootools-more-1.4.0.1" did not work. I haven't gone into the code yet..
Well, I can define zones now at last, it's so nice!
cheers,
P.S. This Forum system keeps say "Your post looks too spamy for a new user, please remove off-site URLs." to my post for only one ".\net". I spent an hour to find a way to post! VERY VERY FRUSTRATING!
