ZoneMinder 1.25x doesn't send any email alert, or SMS alert.
Hi there,
still another issue with ZoneMinder, it seems unable to send any alert when movement is deteceted and locally recorded. I checked servers twice, but I don't know why it keeps on failing.
Any hint to know where to start the debugging process?
Re: ZoneMinder 1.25x doesn't send any email alert, or SMS al
I have somehow similar issue.
Also maybe somebody can give a hint: How the "Score" column is decoded? What "9/10" means (9 is total score or 10 is total score)? Thanks!
- I have configured ZoneMinder and filters as described here.
- I have defined a condition "Total score >= 10".
- For the camera I see the following log in events' list
but nothing is actually reported to email and there is nothing strange in logs.
Id Name Time Secs Frames Score 7870 front-door-7870 2013-02-15 19:56:35 1.88 30/10 9/10 X 7869 front-door-7869 2013-02-15 19:56:31 1.66 25/5 24/28 X
It seems that not so many people were able to get ZoneMinder to work. It appears as if there were too many components and sub-components not playing well with now-standard Ubuntu defaults (such as disk encryption). If you primary goal is to tinker with videosurveillance and learn a few things in the middle, stay ZoneMinder.
If you're only concerned about reliably keep an eye on your belongings, switch to Motion (though you will probably have to script actions to perform, besides the actual recording. Luckily they have a mailing list with knowledgeable people in it), Bluecherry (only for IP cameras, not cabled ones) and the not-so-bad Blue Iris.
I am putting "not-so-bad" because although it is limited by Windows incompatibilities (no native SSL connections, for example, or will crash because of unstable camera drivers, or -previously- incompatible encoding methods), with decent hardware it can do what is expected from it. I was told the new version even has h264 recording now!
On a Mac, you can always go SecuritySpy, which is quite expensive and whose ergonomics defy logic.
None of them are free except Motion, but as they seem to be small, independent developers, just keep in mind the price of the software itself is inferior to the one of a good quality video camera.
It's funny, a thread started with a question (or problem), and now we have a lesson about surveillance software in many different operating systems.
Setting up Zoneminder requires a soft learning curve and spend some reading the forum, but assuming the NOT SO MANY people were able to get Zoneminder work seems a personal assertion based in personal fustration (?)
Regards,
PacoLM
When did you made the poll?.... based in your "huge" experience (25 posts/4 months in the forum)? This is not true, Zoneminder works in many different Linux distributions (I tested it myself, not talking for free), in many different hardwares (ARM based, Intel based, etc), again, tested in person.Cubytus wrote:It seems that not so many people were able to get ZoneMinder to work.
Have you tested it yourself?. I did, and Zoneminder is way easier to install, maintain and more powerful than Motion (even it is a good software!) and Kmotion (the web interface for Motion).Cubytus wrote:It seems that not so many people were able to get ZoneMinder to work.
Regards,
PacoLM
Having posted a topic 4 months ago with NO answer or even asking for clarification of the issues I am facing leads me to think that nobody was ever confronted with the same issue. I tried to make the problems statements as explicit as possible, keeping one topic per problem. The only advice I got about the filters ended up not working, and no one answered it or asked for clarifications, logs, etc, side from "Have you installed ZIP?", which was already installed as it was running on a vanilla Ubuntu distribution.. Truth is ZM is a very complex piece of software, and it's quite hard to know where to start. Remember a surveillance software isn't a toy, but must serve its purpose right away. Spending weeks or even days reading the forums, looking for someone who experienced a similar issue and had it actually solved is leaving the place un-recorded for as many days or weeks.PacoLM wrote:(...)
On the contrary, with ZoneMinder you have to follow an extremely steep learning curve where you have to tackle a tons of problems at once. I appreciate that a piece of software wants to undertake it all, if it were ready to run out-of-the box. First, it never worked properly on Fedora, although it is supposed to be its primary platform: I had to disable the AppArmor policy, and this wasn't said anywhere in the forum. As I got fed up trying on Fedora, I got Ubuntu, where it never went past local recording, and even that didn't go very well as there was no way to prevent the disk from filling up out of the box.
Right from the start, I was unable to:
0- get ALL my cameras working because I couldn't find how to set the arcane settings ZM asks for and auto-detect always gave a "255" error (chinese cloned cameras surely don't help, but Cheese has no problem getting a picture out of those).
1- autodelete of older events to prevent OS crash, keeping an arbitrary number of GB free at all times
2- compress motion events, either as ZIP or TAR.
3- upload events to a SFTP server or FTP
4- send alert emails to both SMS gateway and standard email, with or without attachment
In other words, ZoneMinder never served its purpose.
I have, and I had only one issue with Motion: when the action script was called each time motion was detected, it would saturate the router with connections and made it crash. So the issue was single and probably can be tackled with a bit of external advice on the mailing lists or forums.Have you tested it yourself?. I did, and Zoneminder is way easier to install, maintain and more powerful than Motion (even it is a good software!) and Kmotion (the web interface for Motion).
Regards,
PacoLM
I actually tested each of these software, but now I would like it to perform its duty and leave me in peace
i disagree with your comments but everyone has their own opinion i suppose
but
0, Im assuming IP cameras but i dont know what cheese is.
1, Its there but you need to enable the filter. Its disabled by default.
2, Can be done but you save much if any diskspace that way. I think whot you mean is transcoding the event into another format.
3, Again doable but need to create the filter and needs care else it will swamp your bandwidth
4, it does do this.
ZM is very powerful and flexible but the manual does tell you to do these things. If you have used ubuntu have you followed the wiki guides?
but
4, it does do this.
James Wilson
Dear all,
I think we have deviated from the subject. The question is: how to trace down what is not working in filtering mechanizam?
First of all if I increase LOG_LEVEL_FILE up to DEBUG, grep filter /tmp/zm/zm_debug.log* returns nothing. Then I have checked that zmfilter.pl was actually started in background:
and then I would expect that there is a file /tmp/zm/zm_debug.log.24623, but it does not exist.
However increasing LOG_LEVEL_SYSLOG gave some results:
but there nothing else except these messages. I have FILTER_EXECUTE_INTERVAL set to 10, so I would expect that there is some debug message from zmfilter every 10 seconds. I have a feeling that debug messages are still not bumped to syslog, as they all have INF level.
Now the only way out I see is to dig into /usr/bin/zmfilter.pl to see what is going on.
P.S. I have personally chosen ZoneMinder because it is available in Debain repository. That simplifies the updates.
# ps ax | grep filter
24623 pts/1 S 0:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl
Feb 20 15:51:35 zmdc[24170]: INF ['zmfilter.pl' starting at 13/02/20 15:51:35, pid = 24218]
Feb 20 15:51:35 zmdc[24218]: INF ['zmfilter.pl' started at 13/02/20 15:51:35]
Feb 20 15:51:36 zmfilter[24218]: INF [Scanning for events]
0- you're assuming wrong. These are standard USB webcams.
1- what's the goal of disabling a filter that is essential to stability? For information, one can't just go in the listing of events to delete a few when disk has 0 bytes left. Deleting files by hand leads to inconsistency in the database that will prevent ZM from starting afterwards.
2- I didn't expect any annual compression, only to get a single file to upload instead of many ones.
3- I followed advice received here, copying the exact criteria set forth as an example, and it failed to send anything. Maybe has something to do with number 2, as well as does 4.
I have followed the wiki, third party guides, and was never successful before turning to the forum, which didn't lead to any expected behavior. As an example, no wiki entry warned against using disk encryption or that it would be necessary to deactivate the AppArmor policy.
I'll see what can be extracted from a debug version of the logs.
After adding some more debug messages I have found out that filter needs to be marked as "Run in background":
I didn't pay attention to this checkbox when I was saving the filter.
How to interpret this option? What would it mean "run filter in foreground"?
select * from Filters where Background = 1 and ...
0, ok but ive personally never used usb cams. So i cant really help there. But if they can be seen in linux then zm should be able to use themCubytus wrote:0- you're assuming wrong. These are standard USB webcams.
1, i can see that point but also the reverse is true if it deleted stuff on its own then zm could be critisised. Plus if you use seperate partitions for your storage it wouldnt break the os.
2, ok
3, Unknown. All i know is it can and i have used it to do so. It could be many things.
re other post and foreground vs background. Background tasks work automatically forground tasks are there to be called manually only.
James Wilson
2, ok
James Wilson
The reason for 0 is that webcams are actually the cheapest and most straightforward way to record a picture. If I could get webcams to work, then I may start thinking about IP cameras. Even a cheap IP cam is $50, that's not small change.jameswilson wrote: 0, ok but ive personally never used usb cams. So i cant really help there. But if they can be seen in linux then zm should be able to use them
2, ok
1- For this point, I can understand that ZM may have been criticized if it didn't explicitely tell about this filter. But then again, being criticized because some events would have been deleted due to lack of hard drive space, or being criticized because of a currupted database due to 0-bytes left on the drive, which one is worse? Don't get me started on paths. ZoneMinder has EIGHT paths to cater to, and it is not clear from the start how these different paths are used and in what order when an upload file is created. This raised the number of possible failure points. Besides, I first used a recommended setup for Ubuntu and Fedora: have a separate /home partition. I understand that GNU/Linux's norm is to use one path for a precise purpose and not anything else. However, this greatly complicates matters for end-users who just want a worry-free recording system (after all, isn't videosurveillance all about being freed from worries?). It would be much more flexible if it resided as user application, within the /home directory.
As for the upload filter, it was set to run in the background as shown here, with the exact same settings. With debug logging, I get this:
Feb 22 00:06:08 usager-R510-G-ABM3A9 zmfilter[25232]: ERR [Zip error: 4#012 ]
Feb 22 00:06:08 usager-R510-G-ABM3A9 zmfilter[25232]: INF [Creating upload file '/home/user/Videos/upload/Webcam-8.zip', 3371 files]
Feb 22 00:06:10 usager-R510-G-ABM3A9 zmfilter[25232]: ERR [Zip error: 4#012 ]
Feb 22 00:06:10 usager-R510-G-ABM3A9 zmfilter[25232]: INF [Creating upload file '/home/user/Videos/upload/Webcam-9.zip', 12823 files]
Feb 22 00:06:15 usager-R510-G-ABM3A9 zmfilter[25232]: ERR [Zip error: 4#012 ]
Alerts are not sent either:
Feb 22 00:07:07 usager-R510-G-ABM3A9 nullmailer[1204]: Starting delivery: protocol: --port=25 host: mail.myserver.net file: 1361105401.2235
Feb 22 00:07:07 usager-R510-G-ABM3A9 nullmailer[1204]: Sending failed: Could not exec program
Feb 22 00:07:07 usager-R510-G-ABM3A9 nullmailer[1204]: Starting delivery: protocol: --port=25 host: mail.myserver.net file: 1356242906.5525
Feb 22 00:07:07 usager-R510-G-ABM3A9 nullmailer[1204]: Starting delivery: protocol: --port=25 host: mail.myserver.net file: 1360501076.25589
Oh, the all-mighty "it works on my machine". Mine is a vanilla Ubuntu 12.04LTS, nothing more, nothing less. I didn't dare try the server version yet that would normally be recommended for maximum performance.PacoLM wrote:Both (Zip and email) works in my system (debian wheezy server). And also worked in Zoneminder installed in a Cubox (ubuntu, archlinux, debian), a Guruplug server plus (debian), a Raspberry Pi (debian) and some Intel based computers (debian, ubuntu, archlinux) I´ve played with for years...
So, it's your configuration/system/installation, not Zoneminder.
1- Could you try to manually run the zip filter (I mean, zip the files using the command line), maybe the script uses some flag that is not supported by the version of zip installed.
2- Instead of using nullmailer, use postfix, I could help you setting it up if you have problems.
Regards,
PacoLM
1- WORKS with command:
$ zip -r /home/usager/Videos/upload/test.zip /usr/share/zoneminder/events/1/12/12/26/02/13/19/
All log files were set to output debug level info:
I still get tons of these lines, with each time a similarly named filed, and always the same error.
Feb 27 23:33:50 usager-R510-G-ABM3A9 zmfilter[26082]: INF [Creating upload file '/home/user/Videos/upload/Webcam-2.zip', 260 files]
Feb 27 23:33:51 usager-R510-G-ABM3A9 zmfilter[26082]: ERR [Zip error: 4#012 ]
4 zip was unable to allocate memory for one or more
buffers during program initialization.
2- One problem at a time, I will try to set either nullmailer or postfix once I get the upload system working.
