Ubiquity AirCam
Ubiquity AirCam
Anyone had any success with a Ubuity AirCam on ZoneMinder 1.24.4? Running on Ubuntu 11.10. I cannot get video. I can view the camera feed via a browser using RTP. I think my problem is with the "Remote Host Path". Anyone know what the correct path should be?
Re: Ubiquity AirCam
Here are the URLS and their resolutions
rtsp://aircam_ip:554/live/ch00_0 1280x720
rtsp://aircam_ip:554/live/ch01_0 640x368
rtsp://aircam_ip:554/live/ch02_0 320x192
rtsp://aircam_ip:554/live/ch03_0 160x96
Source Type: FFmpeg
FPS: both blank - you should set this on the camera
Source Path (pick one from above)
24 bit colour
width x height from above.
Here is a sample, ours was slightly out of focus so check it first. (wont let my post the url as Im a new user!) Add http
imm.io/XlhU
Source Type: FFmpeg
24 bit colour
imm.io/XlhU
Re: Ubiquity AirCam
Sample as attachment
- aircam sample
- 055-capture.jpg (58.76 KiB) Viewed 4406 times
