First of all I would like to say that I find ZM fantastic! It is very easy to install and configure and works very well. I just have a little problem I can't find any thread talking about that: I would like to export an event as a video as described here http://www.zoneminder.com/wiki/index.ph ... t_as_video but the Video menu doesn't show. I have installed ffmpeg so I can do it manually but I would like to know if it is a configuration problem or a bug?
Video menu not shown
- Selection_022.png (41.28 KiB) Viewed 1694 times
Re: Video menu not shown
I have the same issue! Please guys can you tell us how to do it?
Many thanks...
Many thanks...
Check your options::images tab to make sure ffmpeg is enabled and has a correct path
