I had my ZM setup just great for the past year. Then I thought I would explore some features and changed the skin from Classic to XML. Now all I see is XML text when I start ZM.
How can I manually change the configuration file to go back to the Classic skin?
Thanks.
Change XML Skin back to Classic
Re: Change XML Skin back to Classic
Thanks. That did it. Glad I didn't have to reinstall.
