I am getting a blank white box where the image should be when trying to view a monitor.
There are no errors in the log. I am using remote IP cameras and they are configured correctly. The cameras where operating fine until I did a system update(gentoo) and then something broke. I am not sure what happened. Can anyone at least point me in the right direction to try and debug this problem.
blank white screen/box where image should be
- Untitled.jpg (35.62 KiB) Viewed 1933 times
Re: blank white screen/box where image should be
When i first installed ZM my cameras did the same thing, i had to put my username:password@ipaddress as the web address. It might be a user setting? Looks like it connects to the camera, but the camera is not giving ZM access to the images.
Aelingil: I need to waste my time, my clients time and another techs time, just to fix a problem with you server & filters?
Tech Joseph: Yes, you are correct.
Check the logs for Shared memory or other type of errors. Logs are useful to debug...
