I've recently set up ZoneMinder with my USB camera and whenever I try to view the video all it shows is a scrambled image. This is on a system that uses Fedora 18.
Here are the camera's characteristics:
Video Device: /dev/video0
General Capabilities
Driver: uvcvideo
Card: VF0640 Live! Cam Socialize
Bus: usb-0000:00:1d.7-2
Version: 3.6.10
Type: 0x4000001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Does not support read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
YUV 4:2:2 (YUYV) (YUYV)
Crop Capabilities
Bounds: 640 x 480
Default: 640 x 480
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Scrambled Image
Scrambled Image
- Scrambled image from ZoneMinder
- 001-capture.jpg (31.66 KiB) Viewed 1539 times
Re: Scrambled Image
What type of camera? Have you read the FAQ? Have you tried changing the input format to YUV as your specs suggest?
