"No main content type" while trying to open rtsp camera
Edu
Post by Edu »
Hello Everyone,
I have 4 cameras that send a RTSP stream as follows:
rtsp://192.168.1.105/live/mpeg4
I can access and view the cameras if I open the stream with a video program like VLC, but when I configure them in ZoneMinder and then try to open the image, I get a "No main content type" message after the Java applet loaded.
Do you know what causes that and how to solve it?
I can ping the cam IP from my ZM server.
Bellow is the cam configuration in ZoneMinder:
Thanks!
bb99
Re: "No main content type" while trying to open rtsp camera
Post by bb99 »
Change your monitor general tab source type to ffmpeg and reconfigure.
Edu
Post by Edu »
Hi, I get the same error with the following configuration
I also tried using rtsp://192.168.1.105/live/mpeg4 as source path
Edu
Post by Edu »
Still having this issue, any ideas?
bb99
Post by bb99 »
View your camera in a browser and look at the source or properties and verify the resolution is 640*480. If it is set the camera resolution in it's firmware to 320*240 and adjust in ZM also to see what happens.
bb99
Post by bb99 »
Also verify the cameras path as you read through the source info.
Edu
Post by Edu »
Well, that's the thing, I can view the stream from VideoLAN but not from ZoneMinder,
VideoLAN says the frame is 640x480, and it opens it with that URL
Is there any way to check if ZoneMinder actually gets the stream but is not able to show it in the browser?
Edu
Post by Edu »
I was using Ubuntu 10.04 LTS
I've rebuilt with Ubuntu 12.10 64bits, no password for the mySQL root, and it worked.
I followed this guide:
http://kirichkov.com/368/howto-make-a-c ... oneminder/
