The first time I build ZM, there were no problems other than warnings and dependancies that I dealt with. Then I started getting compile errors, but it's fixed, for now. I'll give you what I have and we can go from there.
System:
# uname -a
Linux host.domain.tld 2.6.32-279.14.1.el6.x86_64 #1 SMP Tue Nov 6 23:43:09 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
# zmu -d /dev/video0 -q -v
Error, failed to query crop capabilities /dev/video0: Success
2013-05-29 20:00:07.876852 zmu 4959 ERR Failed to query crop capabilities: Invalid argument zm_local_camera.cpp 935
This time around (reinstalling), my log shows a crash in addition to the 3 warnings, to wit:
2013-05-28 22:30:24.855400 zmpkg 4572 INF Command: stop zmpkg.pl
2013-05-28 22:29:07.405250 zmdc 4115 ERR 'zmc -d /dev/video0' exited abnormally, exit status 11 zmdc.pl
2013-05-28 22:29:07.390809 zmc_dvideo0 4535 INF Got signal 11 (Segmentation fault), crashing zm_signal.cpp 73
2013-05-28 22:29:07.119771 zmc_dvideo0 4535 WAR Saturation control is not suppported zm_local_camera.cpp 1396
2013-05-28 22:29:07.119338 zmc_dvideo0 4535 WAR Hue control is not suppported zm_local_camera.cpp 1338
2013-05-28 22:29:07.119089 zmc_dvideo0 4535 WAR Contrast control is not suppported zm_local_camera.cpp 1454
2013-05-28 22:29:07.118437 zmc_dvideo0 4535 INF Starting Capture zmc.cpp 191
# ll /dev
crw-rw----. 1 root root 10, 57 May 28 22:21 vhost-net
crw-rw-rw-+ 1 root video 81, 0 May 28 22:21 video0
crw-rw-rw-. 1 root root 1, 5 May 28 22:21 zero
# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 007: ID 0c45:600d Microdia TwinkleCam USB camera
# xawtv -hwscan
This is xawtv-3.103, running on Linux/x86_64 (2.6.32-279.14.1.el6.x86_64)
looking for available devices
port 63-78
type : Xvideo, image scaler
name : Radeon Textured Video
/dev/video0: OK [ -device /dev/video0 ]
type : libv4l
flags: capture
Chicony 94 0x0c45 0x600d TwinkleCam DC2110 sn9c102 Pas106a Yes gbrg spca5xx
{USB_DEVICE(0x0c45, 0x600d)}, /* spcaCam@120 */
# modprobe -l |grep gspca
kernel/drivers/media/video/gspca/gspca_sn9c20x.ko
kernel/drivers/media/video/gspca/gspca_sonixb.ko
kernel/drivers/media/video/gspca/gspca_sonixj.ko
kernel/drivers/media/video/gspca/gspca_spca500.ko
kernel/drivers/media/video/gspca/gspca_spca501.ko
kernel/drivers/media/video/gspca/gspca_spca505.ko
kernel/drivers/media/video/gspca/gspca_spca506.ko
kernel/drivers/media/video/gspca/gspca_spca508.ko
kernel/drivers/media/video/gspca/gspca_spca561.ko
kernel/drivers/media/video/gspca/gspca_spca1528.ko
Perhaps someone could please suggest what I should do next. Part of me says to get a new cam, but I dunno. Any help will be greatly appreciated and thanks in advance.
Mike
Camera specs:
Video Output CIF(352X288), QVGA(320X240),
QCIF(176X144), QQVGA(160X120)
Video Frame Rate Max. 30 fps
Video Data Format RGB24, I420
File Format
JPEG (still image)
AVI (streaming video)
Camera Control Settings Contrast, Brightness, Saturation,
Sharpness, Exposure
Driver Compliance Video for Windows, WDM, TWAIN
