Hi I bought a NEO Coolcam NIP-02 and I have some issue.
First I don't know Why but when I configure the cam and the ZM to 640*480 it's not working but it works well on 320*240.
Second I'm not able to configure the PTZ controller. If someone can help me
Resolution and PTZ
Re: Resolution and PTZ
Check to see if you're using shared memory. If you are you need to double it. Search the forums for shared memory or read the FAQ on how to. PTZ requires a script specifically for that camera; again search to see if someone has already written one.
Resolution works thx
but can't find Neo coolcam control script
I'm not familiar with your camera but it probably is a knock off of another. If you can figure which one I'll bet you find a script. I'd start by looking at the Foscams.....
I find a Wanscam Script that should work it my cam but I always have an error
status = undefined message = /usr/bin/zmcontrol.pl --autostop --command=moveConRight --id=2=>
I think you either have to change the camera settings in zoneminder to say the camera supports contonus pan/tilt or tell it it does not support it. Depends on the script your using.
Those cameras look like the foscam knock offs and should be able to use the regular foscam script with the version of the camera you have. My PTZ wanscam camera I had to modify the script a bit because of the camera was mounted upside down plus it has 3x zoom which I had to add to the script.
