SOLVED: slow frame rate with axis 205
neuronetv
Post by neuronetv »
I use an axis 205 cam in zm 1.25, the cam has the latest firmware. If I view the live cam image in it's own interface the video is good with high frame rate and smooth video. But if I look at it in zm it's only about 3 - 4 frames per second and it looks crap, and thus the events zm captures are poor too. Is there some setting in zm I can alter to correct this?
I don't have any frame rate restrictions set for the cam in zm or in the cam itself. I've noticed this only happens with the axis 205, I also have an axis 207 and the frame rate on that is good in zm. Thanks for any help.
neuronetv
Post by neuronetv »
it was the Remote Host Path that was wrong.
Both the zm docs and zm's own preset give this as /axis-cgi/jpg/image.cgi?resolution=640x480 but this path gives poor frame rate on the axis 205.
What worked was /axis-cgi/mjpg/video.cgi?. This setting made all the difference and now videos captured by zm have good frame rate and play smooth video.
