Hello.
I need to use an smtp server to send e-mail from the host I am running ZoneMinder on, but the e-mail is disappearing without a trace.
I'm not even sure ZoneMinder is trying to send it - there is nothing in the logs.
This is not a filter-generated email I am trying to get sent, but an event-generated email.
SMTP event e-mail send not working
I went a few rounds with this issue a while back. As far as I can tell the value ZM_EMAIL_HOST does not get passed to ->smtpsend() in zmfilter.pl.
From the Mail::Internet man pages on ->smtpsend() :
You might try adding a "mailhost" line in /etc/hosts. That will at least get your email out the door to the SMTP mailhost. There is however another issue involving the return path set by MIME::Entity and ->smtpsend() that may result in your mailhost dropping the email.
There is a patch that fixed these issues for me here:
http://www.zoneminder.com/forums/viewtopic.php?t=4333
Best regards,
Ross
In my tests "Host" defaulted to "localhost" regardless of what value I set in ZM_EMAIL_HOST. So for all intents and purposes it was the same as using the "sendmail" method.If "Host" is not given then the SMTP host is found by attempting connections first to hosts specified in $ENV{SMTPHOSTS}, a colon separated list, then "mailhost" and "localhost".
Best regards,
Ross
- zoneminder
- Site Admin
- Contact:
