Thank you for a great program!
I am trying to get ZoneMinder working with my DC10+ card for last week or so and I was only partially successfull I must say. one issue is on startup of capture daemon when it uses v4l and the new zoran driver. The error I see in log is from v4l saying that the window buffer has to be set first and then invalid parameter(s). If I do couple of stop/start cycles without changing any settings, It will start to work and I can get it to register events and display pictures and create video using ffmpeg.
I was not able to get the live streaming to work. I read in one of the other threads dated back at the beginning of 2004 that this is due to the mjpeg comp/decomp capability of the DC10+ card, but I don't know if that still applies. Is there any chance for me to get the streaming working?
Thanx for any help.
Roman
Config:
300MHz Intel PentiumII
Fedora core 3 with latest updates
ffmpeg downgraded to 0.4.8 as the 0.4.9 version has some missing symbol problem in libavcodec
Pinnacle Miro Video DC10+ grabber card working flawlessly with XawTV
ZoneMinder 1.21.0
ZoneMinder and Pinnacle DC10+. Again.
- zoneminder
- Site Admin
- Contact:
ZM and DC10+
Hi Phil,
Thank you for your quick reply. Here are outputs from dmesg, zm logs and /var/log/messages in that order. I read your readme,troubleshooting and forum posts several times and still cannot figure out what is wrong.
last lines from dmesg output:
DC10(new)[0]: zoran_open(zmc, pid=[20886]), users(-)=0
adv7176[0]: switched to NTSC
adv7176[0]: switched to pass_through
saa7110[0]: YUV on
DC10(new)[0]: enable_jpg(IDLE)
DC10(new)[0]: setup_window() - frame buffer has to be set first
DC10(new)[0]: set_vfe() - width = 320, height = 240
DC10(new)[0]: zoran_close(zmc, pid=[20886]), users(+)=1
DC10(new)[0]: interrupts received: GIRQ1:16288 queue_state=0/0/0/0
saa7110[0]: YUV off
adv7176[0]: switched to color_bar
DC10(new)[0]: zoran_open(zmc, pid=[20965]), users(-)=0
saa7110[0]: YUV on
DC10(new)[0]: zoran_close(zmc, pid=[20965]), users(+)=1
DC10(new)[0]: interrupts received: GIRQ1:213235 queue_state=0/0/0/0
saa7110[0]: YUV off
DC10(new)[0]: zoran_open(zmc, pid=[21902]), users(-)=0
saa7110[0]: YUV on
DC10(new)[0]: zoran_close(zmc, pid=[21902]), users(+)=1
DC10(new)[0]: interrupts received: GIRQ1:76527 queue_state=0/0/0/0
saa7110[0]: YUV off
DC10(new)[0]: zoran_open(zmc, pid=[22361]), users(-)=0
saa7110[0]: YUV on
DC10(new)[0]: zoran_close(zmc, pid=[22361]), users(+)=1
DC10(new)[0]: interrupts received: GIRQ1:10882 queue_state=0/0/0/0
saa7110[0]: YUV off
DC10(new)[0]: zoran_open(zmc, pid=[22413]), users(-)=0
saa7110[0]: YUV on
DC10(new)[0]: zoran_close(zmc, pid=[22413]), users(+)=1
DC10(new)[0]: interrupts received: GIRQ1:18695 queue_state=0/0/0/0
saa7110[0]: YUV off
DC10(new)[0]: zoran_open(zmc, pid=[22502]), users(-)=0
saa7110[0]: YUV on
cat /tmp/zm* output:
Found database monitor '1', got 0 events
Found filesystem monitor '1', got 14 events
Filesystem event '1/35' does not exist in database, deleting
Filesystem event '1/33' does not exist in database, deleting
Filesystem event '1/32' does not exist in database, deleting
Filesystem event '1/39' does not exist in database, deleting
Filesystem event '1/40' does not exist in database, deleting
Filesystem event '1/36' does not exist in database, deleting
Filesystem event '1/41' does not exist in database, deleting
Filesystem event '1/42' does not exist in database, deleting
Filesystem event '1/38' does not exist in database, deleting
Filesystem event '1/34' does not exist in database, deleting
Filesystem event '1/37' does not exist in database, deleting
Filesystem event '1/43' does not exist in database, deleting
Filesystem event '1/44' does not exist in database, deleting
Filesystem event '1/31' does not exist in database, deleting
Found orphaned frame records for event '31', deleting
Found orphaned frame records for event '32', deleting
Found orphaned frame records for event '33', deleting
Found orphaned frame records for event '34', deleting
Found orphaned frame records for event '35', deleting
Found orphaned frame records for event '36', deleting
Found orphaned frame records for event '37', deleting
Found orphaned frame records for event '38', deleting
Found orphaned frame records for event '39', deleting
Found orphaned frame records for event '40', deleting
Found orphaned frame records for event '41', deleting
Found orphaned frame records for event '42', deleting
Found orphaned frame records for event '43', deleting
Found orphaned frame records for event '44', deleting
Found orphaned statistic records for event '31', deleting
Found orphaned statistic records for event '32', deleting
Found orphaned statistic records for event '33', deleting
Found orphaned statistic records for event '34', deleting
Found orphaned statistic records for event '35', deleting
Found orphaned statistic records for event '36', deleting
Found orphaned statistic records for event '37', deleting
Found orphaned statistic records for event '38', deleting
Found orphaned statistic records for event '39', deleting
Found orphaned statistic records for event '40', deleting
Found orphaned statistic records for event '41', deleting
Found orphaned statistic records for event '42', deleting
Found orphaned statistic records for event '43', deleting
Found orphaned statistic records for event '44', deleting
Found filesystem monitor '1', got 0 events
Server starting at 05/04/23 08:47:00
'zmc -d 0' started at 05/04/23 08:47:04
'zmc -d 0' starting at 05/04/23 08:47:04, pid = 20548
'zmc -d 0' crashed at 05/04/23 08:47:04, exit status 255
'zmc -d 0' starting at 05/04/23 08:47:04, pid = 20550
Can't select: No child processes at /usr/local/bin/zmdc.pl line 593.
Server starting at 05/04/23 08:47:06
'zma -m 1' started at 05/04/23 08:47:09
'zma -m 1' starting at 05/04/23 08:47:09, pid = 20575
'zma -m 1' crashed at 05/04/23 08:47:09, exit status 255
'zma -m 1' starting at 05/04/23 08:47:09, pid = 20578
Server starting at 05/04/23 08:47:10
'zmfilter.pl' started at 05/04/23 08:47:14
'zmfilter.pl' starting at 05/04/23 08:47:14, pid = 20602
'zmaudit.pl -d 900 -y' started at 05/04/23 08:47:16
'zmaudit.pl -d 900 -y' starting at 05/04/23 08:47:16, pid = 20606
'zmwatch.pl' started at 05/04/23 08:47:19
'zmwatch.pl' starting at 05/04/23 08:47:19, pid = 20611
'zmupdate.pl -c' started at 05/04/23 08:47:22
'zmupdate.pl -c' starting at 05/04/23 08:47:22, pid = 20615
'zmaudit.pl -d 900 -y' stopping at 05/04/23 08:48:05
'zmaudit.pl -d 900 -y' died at 05/04/23 08:48:05, signal 14
'zmwatch.pl ' stopping at 05/04/23 08:48:05
'zmwatch.pl ' died at 05/04/23 08:48:05, signal 14
'zmfilter.pl ' stopping at 05/04/23 08:48:05
'zmfilter.pl ' died at 05/04/23 08:48:05, signal 14
'zmupdate.pl -c' stopping at 05/04/23 08:48:05
'zmupdate.pl -c' died at 05/04/23 08:48:05, signal 14
Server shutdown at 05/04/23 08:48:16
Server starting at 05/04/23 08:48:58
'zmc -d 0' started at 05/04/23 08:49:02
'zmc -d 0' starting at 05/04/23 08:49:02, pid = 20861
'zma -m 1' started at 05/04/23 08:49:04
'zma -m 1' starting at 05/04/23 08:49:04, pid = 20865
'zmfilter.pl' started at 05/04/23 08:49:12
'zmfilter.pl' starting at 05/04/23 08:49:12, pid = 20869
'zmaudit.pl -d 900 -y' started at 05/04/23 08:49:21
'zmaudit.pl -d 900 -y' starting at 05/04/23 08:49:21, pid = 20873
'zmwatch.pl' started at 05/04/23 08:49:28
'zmwatch.pl' starting at 05/04/23 08:49:28, pid = 20878
'zmupdate.pl -c' started at 05/04/23 08:49:34
'zmupdate.pl -c' starting at 05/04/23 08:49:34, pid = 20883
'zmc -d 0' stopping at 05/04/23 09:15:23
'zmc -d 0' died at 05/04/23 09:15:23
'zmc -d 0' started at 05/04/23 09:15:23
'zmc -d 0' starting at 05/04/23 09:15:23, pid = 21145
'zmc -d 0' stopping at 05/04/23 09:21:16
'zmc -d 0' died at 05/04/23 09:21:16
'zmc -d 0' started at 05/04/23 09:21:16
'zmc -d 0' starting at 05/04/23 09:21:16, pid = 21298
'zmc -d 0' stopping at 05/04/23 09:26:59
'zmc -d 0' died at 05/04/23 09:26:59
'zmc -d 0' started at 05/04/23 09:26:59
'zmc -d 0' starting at 05/04/23 09:26:59, pid = 21356
'zmc -d 0' stopping at 05/04/23 10:10:32
'zmc -d 0' died at 05/04/23 10:10:32
'zmc -d 0' started at 05/04/23 10:10:34
'zmc -d 0' starting at 05/04/23 10:10:34, pid = 22106
'zma -m 1' stopping at 05/04/23 10:10:45
'zma -m 1' died at 05/04/23 10:10:45
'zmc -d 0' stopping at 05/04/23 10:49:32
'zmc -d 0' died at 05/04/23 10:49:32
'zmc -d 0' started at 05/04/23 10:49:32
'zmc -d 0' starting at 05/04/23 10:49:32, pid = 22974
'zmc -d 0' stopping at 05/04/23 10:49:45
'zmc -d 0' died at 05/04/23 10:49:45
'zmc -d 0' started at 05/04/23 10:49:45
'zmc -d 0' starting at 05/04/23 10:49:45, pid = 22982
'zmc -d 0' stopping at 05/04/23 18:15:14
'zmc -d 0' died at 05/04/23 18:15:14
'zmc -d 0' starting at 05/04/23 18:15:14, pid = 608
'zmc -d 0' started at 05/04/23 18:15:14
'zmc -d 0' stopping at 05/04/24 04:07:52
'zmc -d 0' died at 05/04/24 04:07:52
'zmc -d 0' started at 05/04/24 04:07:52
'zmc -d 0' starting at 05/04/24 04:07:52, pid = 9299
'zmc -d 0' stopping at 05/04/24 04:28:45
'zmc -d 0' died at 05/04/24 04:28:46
'zmc -d 0' started at 05/04/24 04:28:46
'zmc -d 0' starting at 05/04/24 04:28:46, pid = 26435
'zmc -d 0' stopping at 05/04/24 21:49:46
'zmc -d 0' died at 05/04/24 21:49:46
'zmc -d 0' started at 05/04/24 21:49:47
'zmc -d 0' starting at 05/04/24 21:49:47, pid = 17410
Can't find process with command of 'zma -m 1'
'zma -m 1' starting at 05/04/24 21:49:51, pid = 17418
'zma -m 1' started at 05/04/24 21:49:51
'zmc -d 0' stopping at 05/04/24 22:21:27
'zmc -d 0' died at 05/04/24 22:21:28
'zmc -d 0' started at 05/04/24 22:21:28
'zmc -d 0' starting at 05/04/24 22:21:28, pid = 17526
'zmc -d 0' stopping at 05/04/24 22:26:30
'zmc -d 0' died at 05/04/24 22:26:30
'zmc -d 0' started at 05/04/24 22:26:30
'zmc -d 0' starting at 05/04/24 22:26:30, pid = 17569
'zmc -d 0' stopping at 05/04/24 22:30:39
'zmc -d 0' died at 05/04/24 22:30:39
'zmc -d 0' starting at 05/04/24 22:30:40, pid = 17602
'zmc -d 0' started at 05/04/24 22:30:40
'zma -m 1' stopping at 05/04/24 22:30:50
'zma -m 1' died at 05/04/24 22:30:50
'zmc -d 0' stopping at 05/04/25 04:02:12
'zmc -d 0' died at 05/04/25 04:02:12
'zmc -d 0' started at 05/04/25 04:02:12
'zmc -d 0' starting at 05/04/25 04:02:12, pid = 18255
'zmc -d 0' stopping at 05/04/25 08:21:32
'zmc -d 0' died at 05/04/25 08:21:32
'zmc -d 0' starting at 05/04/25 08:21:33, pid = 19007
'zmc -d 0' started at 05/04/25 08:21:33
'zma -m 1' started at 05/04/25 08:21:37
'zma -m 1' starting at 05/04/25 08:21:37, pid = 19015
'zmc -d 0' stopping at 05/04/25 09:37:42
'zmc -d 0' died at 05/04/25 09:37:42
'zmc -d 0' started at 05/04/25 09:37:42
'zmc -d 0' starting at 05/04/25 09:37:42, pid = 19429
'zmc -d 0' stopping at 05/04/25 09:43:56
'zmc -d 0' died at 05/04/25 09:43:56
'zmc -d 0' started at 05/04/25 09:43:56
'zmc -d 0' starting at 05/04/25 09:43:56, pid = 19526
'zmc -d 0' stopping at 05/04/25 10:39:41
'zmc -d 0' died at 05/04/25 10:39:41
'zmc -d 0' starting at 05/04/25 10:39:41, pid = 20368
'zmc -d 0' started at 05/04/25 10:39:41
'zmc -d 0' stopping at 05/04/25 10:39:53
'zmc -d 0' died at 05/04/25 10:39:53
'zmc -d 0' started at 05/04/25 10:39:53
'zmc -d 0' starting at 05/04/25 10:39:53, pid = 20376
'zmc -d 0' stopping at 05/04/25 10:40:04
'zmc -d 0' died at 05/04/25 10:40:04
'zmc -d 0' started at 05/04/25 10:40:04
'zmc -d 0' starting at 05/04/25 10:40:04, pid = 20389
'zmc -d 0' stopping at 05/04/25 10:57:30
'zmc -d 0' died at 05/04/25 10:57:30
'zmc -d 0' started at 05/04/25 10:57:30
'zmc -d 0' starting at 05/04/25 10:57:30, pid = 20649
'zmc -d 0' stopping at 05/04/25 10:57:42
'zmc -d 0' died at 05/04/25 10:57:42
'zmc -d 0' starting at 05/04/25 10:57:42, pid = 20661
'zmc -d 0' started at 05/04/25 10:57:42
'zmc -d 0' stopping at 05/04/25 11:11:48
'zmc -d 0' died at 05/04/25 11:11:48
'zmc -d 0' started at 05/04/25 11:11:48
'zmc -d 0' starting at 05/04/25 11:11:48, pid = 20886
'zmc -d 0' stopping at 05/04/25 11:16:21
'zmc -d 0' died at 05/04/25 11:16:21
'zmc -d 0' started at 05/04/25 11:16:21
'zmc -d 0' starting at 05/04/25 11:16:21, pid = 20965
'zmc -d 0' stopping at 05/04/25 12:15:39
'zmc -d 0' died at 05/04/25 12:15:39
'zmc -d 0' started at 05/04/25 12:15:39
'zmc -d 0' starting at 05/04/25 12:15:39, pid = 21902
'zmc -d 0' stopping at 05/04/25 12:36:56
'zmc -d 0' died at 05/04/25 12:36:56
'zmc -d 0' started at 05/04/25 12:36:56
'zmc -d 0' starting at 05/04/25 12:36:56, pid = 22361
'zmc -d 0' stopping at 05/04/25 12:39:58
'zmc -d 0' died at 05/04/25 12:39:58
'zmc -d 0' started at 05/04/25 12:39:58
'zmc -d 0' starting at 05/04/25 12:39:58, pid = 22413
'zmc -d 0' stopping at 05/04/25 12:45:10
'zmc -d 0' died at 05/04/25 12:45:10
'zmc -d 0' started at 05/04/25 12:45:10
'zmc -d 0' starting at 05/04/25 12:45:10, pid = 22502
Scanning for events
Scanning for events
Command: start
Executing: /usr/local/bin/zmdc.pl check
Removing shared memory
Executing: /usr/local/bin/zmfix
Executing: /usr/local/bin/zmdc.pl status
Executing: /usr/local/bin/zmdc.pl start zmc -d 0
Executing: /usr/local/bin/zmdc.pl start zma -m 1
Executing: /usr/local/bin/zmdc.pl start zmfilter.pl
Executing: /usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y
Executing: /usr/local/bin/zmdc.pl start zmwatch.pl
Executing: /usr/local/bin/zmdc.pl start zmupdate.pl -c
Command: stop
Executing: /usr/local/bin/zmdc.pl shutdown
Command: start
Update agent starting at 05/04/23 08:47:26
Update agent starting at 05/04/23 08:49:37
Checking for updates at 05/04/23 16:49:37
Got version: '1.21.0'
Checking for updates at 05/04/24 16:49:41
Watchdog starting at 05/04/23 08:47:20
Watchdog pausing for 30 seconds
Watchdog starting at 05/04/23 08:49:30
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 6 seconds (1114262122-1114262116)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 14 seconds (1114262474-1114262460)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 15 seconds (1114262817-1114262802)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 10 seconds (1114267770-1114267760)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114267783-1114267774)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114294513-1114294504)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114330071-1114330062)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 11 seconds (1114331324-1114331313)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 6 seconds (1114395686-1114395680)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 14 seconds (1114395989-1114395975)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 6 seconds (1114416131-1114416125)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 7 seconds (1114436261-1114436254)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 12 seconds (1114436634-1114436622)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 6 seconds (1114439980-1114439974)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114439991-1114439982)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 10 seconds (1114440003-1114439993)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 11 seconds (1114441049-1114441038)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114441060-1114441051)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 13 seconds (1114441906-1114441893)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 15 seconds (1114442179-1114442164)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 11 seconds (1114445736-1114445725)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 13 seconds (1114447015-1114447002)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 9 seconds (1114447197-1114447188)
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 14 seconds (1114447509-1114447495)
tail -200 /var/log/messages
Apr 25 12:25:40 pluto zmc_d0[21902]: INF [Home: 18000 - Capturing at 30.30 fps]
Apr 25 12:25:42 pluto zma_m1[19015]: INF [Home: 425000 - Processing at 29.41 fps]
Apr 25 12:26:03 pluto crond(pam_unix)[22193]: session closed for user root
Apr 25 12:26:14 pluto zmc_d0[21902]: INF [Home: 19000 - Capturing at 29.41 fps]
Apr 25 12:26:15 pluto zma_m1[19015]: INF [Home: 426000 - Processing at 30.30 fps]
Apr 25 12:26:47 pluto zmc_d0[21902]: INF [Home: 20000 - Capturing at 30.30 fps]
Apr 25 12:26:49 pluto zma_m1[19015]: INF [Home: 427000 - Processing at 29.41 fps]
Apr 25 12:27:20 pluto zmc_d0[21902]: INF [Home: 21000 - Capturing at 30.30 fps]
Apr 25 12:27:22 pluto zma_m1[19015]: INF [Home: 428000 - Processing at 30.30 fps]
Apr 25 12:27:54 pluto zmc_d0[21902]: INF [Home: 22000 - Capturing at 29.41 fps]
Apr 25 12:27:55 pluto zma_m1[19015]: INF [Home: 429000 - Processing at 30.30 fps]
Apr 25 12:28:25 pluto nmbd[3176]: [2005/04/25 12:28:25, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:28:25 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:28:27 pluto zmc_d0[21902]: INF [Home: 23000 - Capturing at 30.30 fps]
Apr 25 12:28:29 pluto zma_m1[19015]: INF [Home: 430000 - Processing at 29.41 fps]
Apr 25 12:29:01 pluto zmc_d0[21902]: INF [Home: 24000 - Capturing at 29.41 fps]
Apr 25 12:29:02 pluto zma_m1[19015]: INF [Home: 431000 - Processing at 30.30 fps]
Apr 25 12:29:34 pluto zmc_d0[21902]: INF [Home: 25000 - Capturing at 30.30 fps]
Apr 25 12:29:41 pluto zma_m1[19015]: INF [Home: 432000 - Processing at 25.64 fps]
Apr 25 12:30:01 pluto crond(pam_unix)[22257]: session opened for user root by (uid=0)
Apr 25 12:30:03 pluto crond(pam_unix)[22258]: session opened for user root by (uid=0)
Apr 25 12:30:03 pluto crond(pam_unix)[22257]: session closed for user root
Apr 25 12:30:08 pluto zmc_d0[21902]: INF [Home: 26000 - Capturing at 29.41 fps]
Apr 25 12:30:14 pluto zma_m1[19015]: INF [Home: 433000 - Processing at 30.30 fps]
Apr 25 12:30:41 pluto zmc_d0[21902]: INF [Home: 27000 - Capturing at 30.30 fps]
Apr 25 12:30:48 pluto zma_m1[19015]: INF [Home: 434000 - Processing at 29.41 fps]
Apr 25 12:31:01 pluto crond(pam_unix)[22258]: session closed for user root
Apr 25 12:31:14 pluto zmc_d0[21902]: INF [Home: 28000 - Capturing at 30.30 fps]
Apr 25 12:31:21 pluto zma_m1[19015]: INF [Home: 435000 - Processing at 30.30 fps]
Apr 25 12:31:26 pluto nmbd[3176]: [2005/04/25 12:31:26, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:31:26 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:31:48 pluto zmc_d0[21902]: INF [Home: 29000 - Capturing at 29.41 fps]
Apr 25 12:31:55 pluto zma_m1[19015]: INF [Home: 436000 - Processing at 29.41 fps]
Apr 25 12:32:21 pluto zmc_d0[21902]: INF [Home: 30000 - Capturing at 30.30 fps]
Apr 25 12:32:28 pluto zma_m1[19015]: INF [Home: 437000 - Processing at 30.30 fps]
Apr 25 12:32:55 pluto zmc_d0[21902]: INF [Home: 31000 - Capturing at 29.41 fps]
Apr 25 12:33:02 pluto zma_m1[19015]: INF [Home: 438000 - Processing at 29.41 fps]
Apr 25 12:33:28 pluto zmc_d0[21902]: INF [Home: 32000 - Capturing at 30.30 fps]
Apr 25 12:33:36 pluto zma_m1[19015]: INF [Home: 439000 - Processing at 29.41 fps]
Apr 25 12:34:02 pluto zmc_d0[21902]: INF [Home: 33000 - Capturing at 29.41 fps]
Apr 25 12:34:10 pluto zma_m1[19015]: INF [Home: 440000 - Processing at 29.41 fps]
Apr 25 12:34:34 pluto nmbd[3176]: [2005/04/25 12:34:34, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:34:34 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:34:35 pluto zmc_d0[21902]: INF [Home: 34000 - Capturing at 30.30 fps]
Apr 25 12:34:49 pluto zma_m1[19015]: INF [Home: 441000 - Processing at 25.64 fps]
Apr 25 12:35:02 pluto crond(pam_unix)[22333]: session opened for user root by (uid=0)
Apr 25 12:35:08 pluto zmc_d0[21902]: INF [Home: 35000 - Capturing at 30.30 fps]
Apr 25 12:35:22 pluto zma_m1[19015]: INF [Home: 442000 - Processing at 30.30 fps]
Apr 25 12:35:42 pluto zmc_d0[21902]: INF [Home: 36000 - Capturing at 29.41 fps]
Apr 25 12:35:56 pluto zma_m1[19015]: INF [Home: 443000 - Processing at 29.41 fps]
Apr 25 12:36:00 pluto crond(pam_unix)[22333]: session closed for user root
Apr 25 12:36:15 pluto zmc_d0[21902]: INF [Home: 37000 - Capturing at 30.30 fps]
Apr 25 12:36:29 pluto zma_m1[19015]: INF [Home: 444000 - Processing at 30.30 fps]
Apr 25 12:36:42 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:36:56 pluto zmc_d0[21902]: INF [Got TERM signal, exiting]
Apr 25 12:36:56 pluto zmc_d0[21902]: ERR [Sync failure for frame 1: Interrupted system call]
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: zoran_close(zmc, pid=[21902]), users(+)=1
Apr 25 12:36:56 pluto kernel: adv7176[0]: switched to pass_through
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: enable_jpg(IDLE)
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: interrupts received: GIRQ1:76527 queue_state=0/0/0/0
Apr 25 12:36:56 pluto kernel: saa7110[0]: YUV off
Apr 25 12:36:56 pluto kernel: adv7176[0]: switched to color_bar
Apr 25 12:36:56 pluto zmc_d0[22361]: INF [Debug Level = 0, Debug Log = <none>]
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: zoran_open(zmc, pid=[22361]), users(-)=0
Apr 25 12:36:56 pluto kernel: adv7176[0]: switched to NTSC
Apr 25 12:36:56 pluto kernel: saa7110[0]: YUV on
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: setup_window() - frame buffer has to be set first
Apr 25 12:36:56 pluto zmc_d0[22361]: ERR [Failed to set window attributes: Invalid argument]
Apr 25 12:36:56 pluto zmc_d0[22361]: INF [Starting Capture]
Apr 25 12:36:56 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:37:17 pluto zma_m1[19015]: INF [Home: 445000 - Processing at 20.83 fps]
Apr 25 12:37:30 pluto zmc_d0[22361]: INF [Home: 1000 - Capturing at 29.41 fps]
Apr 25 12:37:35 pluto nmbd[3176]: [2005/04/25 12:37:35, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:37:35 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:37:52 pluto zma_m1[19015]: INF [Home: 446000 - Processing at 28.57 fps]
Apr 25 12:38:03 pluto zmc_d0[22361]: INF [Home: 2000 - Capturing at 30.30 fps]
Apr 25 12:38:25 pluto zma_m1[19015]: INF [Home: 447000 - Processing at 30.30 fps]
Apr 25 12:38:37 pluto zmc_d0[22361]: INF [Home: 3000 - Capturing at 29.41 fps]
Apr 25 12:38:58 pluto zma_m1[19015]: INF [Home: 448000 - Processing at 30.30 fps]
Apr 25 12:39:10 pluto zmc_d0[22361]: INF [Home: 4000 - Capturing at 30.30 fps]
Apr 25 12:39:32 pluto zma_m1[19015]: INF [Home: 449000 - Processing at 29.41 fps]
Apr 25 12:39:43 pluto zmc_d0[22361]: INF [Home: 5000 - Capturing at 30.30 fps]
Apr 25 12:39:48 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:39:58 pluto zmc_d0[22361]: INF [Got TERM signal, exiting]
Apr 25 12:39:58 pluto zmc_d0[22361]: ERR [Sync failure for frame 1: Interrupted system call]
Apr 25 12:39:58 pluto kernel: DC10(new)[0]: zoran_close(zmc, pid=[22361]), users(+)=1
Apr 25 12:39:58 pluto zmc_d0[22413]: INF [Debug Level = 0, Debug Log = <none>]
Apr 25 12:39:58 pluto kernel: adv7176[0]: switched to pass_through
Apr 25 12:39:58 pluto kernel: DC10(new)[0]: enable_jpg(IDLE)
Apr 25 12:39:58 pluto kernel: DC10(new)[0]: interrupts received: GIRQ1:10882 queue_state=0/0/0/0
Apr 25 12:39:58 pluto kernel: saa7110[0]: YUV off
Apr 25 12:39:58 pluto kernel: adv7176[0]: switched to color_bar
Apr 25 12:39:58 pluto kernel: DC10(new)[0]: zoran_open(zmc, pid=[22413]), users(-)=0
Apr 25 12:39:58 pluto kernel: adv7176[0]: switched to NTSC
Apr 25 12:39:58 pluto kernel: saa7110[0]: YUV on
Apr 25 12:39:58 pluto kernel: DC10(new)[0]: setup_window() - frame buffer has to be set first
Apr 25 12:39:58 pluto zmc_d0[22413]: ERR [Failed to set window attributes: Invalid argument]
Apr 25 12:39:59 pluto zmc_d0[22413]: INF [Starting Capture]
Apr 25 12:39:59 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:40:01 pluto crond(pam_unix)[22417]: session opened for user root by (uid=0)
Apr 25 12:40:01 pluto crond(pam_unix)[22416]: session opened for user root by (uid=0)
Apr 25 12:40:07 pluto crond(pam_unix)[22416]: session closed for user root
Apr 25 12:40:16 pluto zma_m1[19015]: INF [Home: 450000 - Processing at 22.73 fps]
Apr 25 12:40:25 pluto nmbd[3176]: [2005/04/25 12:40:25, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:40:25 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:40:32 pluto zmc_d0[22413]: INF [Home: 1000 - Capturing at 30.30 fps]
Apr 25 12:40:50 pluto zma_m1[19015]: INF [Home: 451000 - Processing at 29.41 fps]
Apr 25 12:41:02 pluto crond(pam_unix)[22417]: session closed for user root
Apr 25 12:41:05 pluto zmc_d0[22413]: INF [Home: 2000 - Capturing at 30.30 fps]
Apr 25 12:41:23 pluto zma_m1[19015]: INF [Home: 452000 - Processing at 30.30 fps]
Apr 25 12:41:39 pluto zmc_d0[22413]: INF [Home: 3000 - Capturing at 29.41 fps]
Apr 25 12:41:57 pluto zma_m1[19015]: INF [Home: 453000 - Processing at 29.41 fps]
Apr 25 12:42:12 pluto zmc_d0[22413]: INF [Home: 4000 - Capturing at 30.30 fps]
Apr 25 12:42:31 pluto zma_m1[19015]: INF [Home: 454000 - Processing at 29.41 fps]
Apr 25 12:42:46 pluto zmc_d0[22413]: INF [Home: 5000 - Capturing at 29.41 fps]
Apr 25 12:43:04 pluto zma_m1[19015]: INF [Home: 455000 - Processing at 30.30 fps]
Apr 25 12:43:19 pluto zmc_d0[22413]: INF [Home: 6000 - Capturing at 30.30 fps]
Apr 25 12:43:36 pluto nmbd[3176]: [2005/04/25 12:43:36, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:43:36 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:43:38 pluto zma_m1[19015]: INF [Home: 456000 - Processing at 29.41 fps]
Apr 25 12:43:52 pluto zmc_d0[22413]: INF [Home: 7000 - Capturing at 30.30 fps]
Apr 25 12:44:11 pluto zma_m1[19015]: INF [Home: 457000 - Processing at 30.30 fps]
Apr 25 12:44:26 pluto zmc_d0[22413]: INF [Home: 8000 - Capturing at 29.41 fps]
Apr 25 12:44:45 pluto zma_m1[19015]: INF [Home: 458000 - Processing at 29.41 fps]
Apr 25 12:44:55 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:45:01 pluto crond(pam_unix)[22491]: session opened for user root by (uid=0)
Apr 25 12:45:05 pluto crond(pam_unix)[22491]: session closed for user root
Apr 25 12:45:10 pluto zmc_d0[22413]: INF [Got TERM signal, exiting]
Apr 25 12:45:10 pluto zmc_d0[22413]: ERR [Sync failure for frame 1: Interrupted system call]
Apr 25 12:45:10 pluto kernel: DC10(new)[0]: zoran_close(zmc, pid=[22413]), users(+)=1
Apr 25 12:45:10 pluto kernel: adv7176[0]: switched to pass_through
Apr 25 12:45:10 pluto kernel: DC10(new)[0]: enable_jpg(IDLE)
Apr 25 12:45:10 pluto kernel: DC10(new)[0]: interrupts received: GIRQ1:18695 queue_state=0/0/0/0
Apr 25 12:45:10 pluto kernel: saa7110[0]: YUV off
Apr 25 12:45:11 pluto zmc_d0[22502]: INF [Debug Level = 0, Debug Log = <none>]
Apr 25 12:45:11 pluto kernel: adv7176[0]: switched to color_bar
Apr 25 12:45:11 pluto kernel: DC10(new)[0]: zoran_open(zmc, pid=[22502]), users(-)=0
Apr 25 12:45:11 pluto kernel: adv7176[0]: switched to NTSC
Apr 25 12:45:11 pluto kernel: adv7176[0]: switched to pass_through
Apr 25 12:45:11 pluto kernel: saa7110[0]: YUV on
Apr 25 12:45:11 pluto kernel: DC10(new)[0]: enable_jpg(IDLE)
Apr 25 12:45:11 pluto kernel: DC10(new)[0]: setup_window() - frame buffer has to be set first
Apr 25 12:45:11 pluto zmc_d0[22502]: ERR [Failed to set window attributes: Invalid argument]
Apr 25 12:45:11 pluto zmc_d0[22502]: INF [Starting Capture]
Apr 25 12:45:11 pluto kernel: DC10(new)[0]: set_vfe() - width = 320, height = 240
Apr 25 12:45:34 pluto zma_m1[19015]: INF [Home: 459000 - Processing at 20.41 fps]
Apr 25 12:45:44 pluto zmc_d0[22502]: INF [Home: 1000 - Capturing at 30.30 fps]
Apr 25 12:46:07 pluto zma_m1[19015]: INF [Home: 460000 - Processing at 30.30 fps]
Apr 25 12:46:18 pluto zmc_d0[22502]: INF [Home: 2000 - Capturing at 29.41 fps]
Apr 25 12:46:41 pluto zma_m1[19015]: INF [Home: 461000 - Processing at 29.41 fps]
Apr 25 12:46:43 pluto nmbd[3176]: [2005/04/25 12:46:43, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:46:43 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:46:51 pluto zmc_d0[22502]: INF [Home: 3000 - Capturing at 30.30 fps]
Apr 25 12:47:14 pluto zma_m1[19015]: INF [Home: 462000 - Processing at 30.30 fps]
Apr 25 12:47:24 pluto zmc_d0[22502]: INF [Home: 4000 - Capturing at 30.30 fps]
Apr 25 12:47:47 pluto zma_m1[19015]: INF [Home: 463000 - Processing at 30.30 fps]
Apr 25 12:47:58 pluto zmc_d0[22502]: INF [Home: 5000 - Capturing at 29.41 fps]
Apr 25 12:48:21 pluto zma_m1[19015]: INF [Home: 464000 - Processing at 29.41 fps]
Apr 25 12:48:31 pluto zmc_d0[22502]: INF [Home: 6000 - Capturing at 30.30 fps]
Apr 25 12:48:54 pluto zma_m1[19015]: INF [Home: 465000 - Processing at 30.30 fps]
Apr 25 12:49:05 pluto zmc_d0[22502]: INF [Home: 7000 - Capturing at 29.41 fps]
Apr 25 12:49:27 pluto zma_m1[19015]: INF [Home: 466000 - Processing at 30.30 fps]
Apr 25 12:49:38 pluto zmc_d0[22502]: INF [Home: 8000 - Capturing at 30.30 fps]
Apr 25 12:49:45 pluto nmbd[3176]: [2005/04/25 12:49:45, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:49:45 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:50:01 pluto zma_m1[19015]: INF [Home: 467000 - Processing at 29.41 fps]
Apr 25 12:50:02 pluto crond(pam_unix)[22518]: session opened for user root by (uid=0)
Apr 25 12:50:02 pluto crond(pam_unix)[22519]: session opened for user root by (uid=0)
Apr 25 12:50:11 pluto zmc_d0[22502]: INF [Home: 9000 - Capturing at 30.30 fps]
Apr 25 12:50:15 pluto crond(pam_unix)[22518]: session closed for user root
Apr 25 12:50:34 pluto zma_m1[19015]: INF [Home: 468000 - Processing at 30.30 fps]
Apr 25 12:50:45 pluto zmc_d0[22502]: INF [Home: 10000 - Capturing at 29.41 fps]
Apr 25 12:51:00 pluto crond(pam_unix)[22519]: session closed for user root
Apr 25 12:51:02 pluto sshd(pam_unix)[22532]: session opened for user root by root(uid=0)
Apr 25 12:51:09 pluto zma_m1[19015]: INF [Home: 469000 - Processing at 28.57 fps]
Apr 25 12:51:18 pluto zmc_d0[22502]: INF [Home: 11000 - Capturing at 30.30 fps]
Apr 25 12:51:43 pluto zma_m1[19015]: INF [Home: 470000 - Processing at 29.41 fps]
Apr 25 12:51:52 pluto zmc_d0[22502]: INF [Home: 12000 - Capturing at 29.41 fps]
Apr 25 12:52:17 pluto zma_m1[19015]: INF [Home: 471000 - Processing at 29.41 fps]
Apr 25 12:52:25 pluto nmbd[3176]: [2005/04/25 12:52:25, 0] nmbd/nmbd_packets.c:process_browse_packet(1050)
Apr 25 12:52:25 pluto nmbd[3176]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name PLUTO<00> is one of our names !
Apr 25 12:52:26 pluto zmc_d0[22502]: INF [Home: 13000 - Capturing at 29.41 fps]
Apr 25 12:52:50 pluto zma_m1[19015]: INF [Home: 472000 - Processing at 30.30 fps]
Apr 25 12:52:59 pluto zmc_d0[22502]: INF [Home: 14000 - Capturing at 30.30 fps]
Apr 25 12:53:24 pluto zma_m1[19015]: INF [Home: 473000 - Processing at 29.41 fps]
Apr 25 12:53:32 pluto zmc_d0[22502]: INF [Home: 15000 - Capturing at 30.30 fps]
Apr 25 12:53:57 pluto zma_m1[19015]: INF [Home: 474000 - Processing at 30.30 fps]
Apr 25 12:54:06 pluto zmc_d0[22502]: INF [Home: 16000 - Capturing at 29.41 fps]
Apr 25 12:54:31 pluto zma_m1[19015]: INF [Home: 475000 - Processing at 29.41 fps]
Apr 25 12:54:39 pluto zmc_d0[22502]: INF [Home: 17000 - Capturing at 30.30 fps]
saa7110[0]: YUV on
saa7110[0]: YUV off
saa7110[0]: YUV on
saa7110[0]: YUV off
saa7110[0]: YUV on
saa7110[0]: YUV off
saa7110[0]: YUV on
saa7110[0]: YUV off
saa7110[0]: YUV on
saa7110[0]: YUV off
saa7110[0]: YUV on
Scanning for events
Scanning for events
Command: start
Command: stop
Command: start
Almost working
Hi Phil,
I figured out what the problem with streaming was. Basically, When the monitor browser window was displayed, zms was not running. So I checked all log files including apache and there I saw weird errors about remote side closing connection and broken pipe or something like that. I looked at zms source code, enabled level 9 debuging and rebuilt. Set enviroment parameter QUERY_STRING to whatever the browser was sending and executed zms from command line. And it worked and was continuously dumping output. Without setting the QUERY_STRING zms only prints some info and stops. So i figured, that if I include that in php document, it should do the same. And it did not! It dumped that ELF executable. Of course! That means that my apache does not know how to execute zms executable! It was just sending it as is and that's why it broke the pipe. Unfortunatelly I did not find out yet how to set my apache to recognize zms as executable. I know it recognizes perl/cgi so I renamed zms to zms.pl and pointed to it in options dialog and it started to work (almost). It streams and sends stills, but in streaming you have to play with the window and or stop/pause/play the stream to actually see the image. And even then it stops after few seconds. When you move the window, it is like viewport, you loose the image and when you move it back to the same position on the screen, it appears again. So I am almost there...
Btw. I am using Firefox.
Regards
Roman
Regards
Roman
- zoneminder
- Site Admin
- Contact:
@rronge:
i have one question:
How get you the Pinnacle DC10 to run with Zoneminder??
I've been trying it for two days, but i can't get this
thing to work...
i get only erros like:
what does it mean??
regards,
Thorsten.
thing to work...
v4l_set_format() - video buffer size (128 kB) is too small
DC10plus[0]: zoran_close(zmc, pid=[15787]), users(+)=1
DC10plus[0]: zoran_open(zmc, pid=[15804]), users(-)=0
DC10plus[0]: v4l_set_format() - video buffer size (128 kB) is too small
regards,
Thorsten.
