Zoneminder problem with IE10
Tiggy
Post by Tiggy »
I just had to reinstall my pc and installed windows 7 64 bit which installs IE10 by default.
Now I can't see any image anymore (not even in computability view). I am getting that typical red cross instead of an image (as if the image doesn't exist). Can't see the recorded events eather ...
Running zoneminder 1.25 on an Ubuntu machine with cambozola.jar enabled to see the life streaming.
Everything worked fine on my windows 32 with IE 9 (ie10 on 32bit windows gave same problem) until reinstall and server side nothing changed.
Any idea what I should do? Surfing to my zoneminder site on my iphone works as it should. :cry:
Tiggy
Re: Zoneminder problem with IE10
Post by Tiggy »
Getting these errors in console of ie 10
getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-620107s.sock ) failed: No such file or directory
Tiggy
Post by Tiggy »
Ok nothing wrong to my install so seems.
Adding the site to my intranet sites did the trick.
Internet Options - Security - Local Intranet - Sites -Advanced
Fill in the sites address and click "Add"; then OK :)
SOLVED :D
