How update ZM from 1.25.0 to 1.26.3
topromotion
Post by topromotion »
Hello!
I try to update my ZM from version 1.25.0 to 1.26.3 with
zmupdate.pl --version=1.25.0
but i have: Database already at version 1.25.0, update aborted.
What i must to do for update?
2Psycho
Re: How update ZM from 1.25.0 to 1.26.3
Post by 2Psycho »
The command should be
 zmupdate.pl --user=root --pass=MYSQLROOTPASSWORD
All other actions will happen by it self
Enjoyment Matters
topromotion
I try this command but i have - Database already at version 1.25.0, update aborted. Again.
Whats wrong?
jameswilson
Post by jameswilson »
have you updated the rest correctly, or are you thinking this command will update the lot?
James Wilson
topromotion
I dont update nothing more. What i must to do after unzip archive with source?
jameswilson
that command will only update your db structure etc. You need to update zm first.
James Wilson
topromotion
How i can update zm correctly?
I tried to do in the documentation - http://www.zoneminder.com/wiki/index.ph ... #Upgrading
but nothing came of it.
How did you install it in the first place?
aitzol76
Post by aitzol76 »
I have the same problem as tropomotion. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
aitzol76 wrote:I have the same problem as pepe. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
Did you uninstall the zm 1.25.0 deb package first before you tried to install 1.26.3 from source?
If you didn't then that is the problem.
sudo apt-get remove zoneminder
You can't have both on your system at the same time.
topromotion
Magic919 wrote:How did you install it in the first place?
In first place i install it from sources
Torsten73
Post by Torsten73 »
Iconnor has released bis ppa for ubuntu 12.04. It works fine when the database path in zm.conf is correct.
It should be used on an standard preinstalled 1.25 setup.
Ok. So you've downloaded the new 1.26.3 sources and unpacked, run the bootstrap.sh, run the configure command with options, run make and then make install. Did that all work?
topromotion
Yes, its all works. What's next?
Great. After than just run zmupdate.pl with no arguments.
