How update ZM from 1.25.0 to 1.26.3
Hello!
I try to update my ZM from version 1.25.0 to 1.26.3 with
zmupdate.pl --version=1.25.0
but i have: Database already at version 1.25.0, update aborted.
What i must to do for update?
Re: How update ZM from 1.25.0 to 1.26.3
The command should be
All other actions will happen by it self
zmupdate.pl --user=root --pass=MYSQLROOTPASSWORD
Enjoyment Matters
I try this command but i have - Database already at version 1.25.0, update aborted. Again.
Whats wrong?
Whats wrong?
have you updated the rest correctly, or are you thinking this command will update the lot?
James Wilson
I dont update nothing more. What i must to do after unzip archive with source?
that command will only update your db structure etc. You need to update zm first.
James Wilson
How i can update zm correctly?
I tried to do in the documentation - http://www.zoneminder.com/wiki/index.ph ... #Upgrading
but nothing came of it.
I have the same problem as tropomotion. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
- knight-of-ni
Did you uninstall the zm 1.25.0 deb package first before you tried to install 1.26.3 from source?aitzol76 wrote:I have the same problem as pepe. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
If you didn't then that is the problem.
sudo apt-get remove zoneminder
You can't have both on your system at the same time.
In first place i install it from sourcesMagic919 wrote:How did you install it in the first place?
Iconnor has released bis ppa for ubuntu 12.04. It works fine when the database path in zm.conf is correct.
It should be used on an standard preinstalled 1.25 setup.
Ok. So you've downloaded the new 1.26.3 sources and unpacked, run the bootstrap.sh, run the configure command with options, run make and then make install. Did that all work?topromotion wrote:In first place i install it from sourcesMagic919 wrote:How did you install it in the first place?
Yes, its all works. What's next?Magic919 wrote:Ok. So you've downloaded the new 1.26.3 sources and unpacked, run the bootstrap.sh, run the configure command with options, run make and then make install. Did that all work?topromotion wrote:In first place i install it from sourcesMagic919 wrote:How did you install it in the first place?
