I have another new setup of ZM. I am using a Hauppauge USB2 PVR 2 box for capture. In VLC it works fine by choosing channel 1 for composite. However, I have not been able to set up a monitor with it in ZM.
I ran sudo zmc --device /dev/video0 and generated some of the following logs right away:
2013-09-27 13:05:58.363830 zmwatch[2690].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-1, expected 328, got 316]
2013-09-27 13:05:58.365620 zmwatch[2690].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-1, expected 328, got 316]
2013-09-27 13:05:58.839074 zma_m1[2670].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2013-09-27 13:05:59.560741 zmc_dvideo0[3837].INF-zmc.cpp/191 [Starting Capture]
2013-09-27 13:05:59.562455 zmc_dvideo0[3837].FAT-zm_local_camera.cpp/373 [Video device does not support streaming i/o]
Running zmu -d /dev/video0 -q -v produces the following:
Video Device: /dev/video0
General Capabilities
Driver: pvrusb2
Card: WinTV PVR USB2 Model 29xxx
Bus: usb-0000:00:04.1-3
Version: 3.8.8
Type: 0x1070001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Has tuner
Has audio in and/or out
Has radio
Supports read/write i/o (X)
Does not support async i/o
Does not support streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL-M
PAL-N
PAL-Nc
Formats:
MPEG1/2 (Crop Capabilities
Bounds: 0 x 0
Default: 0 x 0
Current: 720 x 480
Inputs: 4
Input 0
Type: Tuner
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Input 3
Type: Tuner
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
