I have a rather exotic setup, and now I can't get Apache to play nice.
Have seen posts here describing more or less what I want, but in my specific situation I can't make it work.
Sorry for the long posting....
Here we go:
I have two Centos 6.4 machines (earth and vulcan) in a high-available cluster. High availability is necessary for some office collaboration software I have running that needs to be up all the time.
Earth is the primary machine, which has Apache running and is servicing from /var/www/html. This filesystem is mounted by the HA software, and, in case of a failover, will mount over the same location on Vulcan.
Vulcan is the standby machine and the one where the capturecard is installed. Because of the fact that /var/www/html will be overmounted in case of a problem with Earth, I compiled ZM to make use of webdir /usr/local/share/zm and webcgi /usr/local/share/zm/cgi-bin.
By the way, I'm using ZM 1.26.3.
Also on Vulcan, a dedicated Apache server is running for ZM, simply on localhost port 80.
So, recapping :
Earth:
CentOS 6.4, Apache, MySQL, Zarafa (collaboration software), HA-software
primary
Vulcan:
Centos 6.4, Apache for ZM, HA-software.
secondary
Now, the high available Apache instance is the one that services requests from the internet for my domain hanlammerts.mine.nu .
This instance should forward any requests for zm to Vulcan where the dedicated Apache instance for ZM picks up the requests.
Normally this can be done with mod_proxy, and it works, ALMOST.....
Before I go any further: ZoneMinder is working perfectly if I go directly to Vulcan /zm !!
So ZM is working.
This is the config I have on earth for Apache :
ProxyRequests Off
ProxyVia On
ProxyPreserveHost On
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyPass /zm/ http://192.168.0.15/zm/
ProxyPassReverse /zm/ http://192.168.0.15/zm/
ProxyPass /cgi-bin/ http://192.168.0.15/cgi-bin/
ProxyPassReverse /cgi-bin/ http://192.168.0.15/cgi-bin/
Alias /zm "/usr/local/share/zm"
<Directory "/usr/local/share/zm">
Options FollowSymLinks
AllowOverride All
# The code unfortunately uses short tags in many places
php_value short_open_tag 1
</Directory>
ScriptAlias /cgi-bin "/usr/local/share/zm/cgi-bin"
<Directory "/usr/local/share/zm/cgi-bin">
AllowOverride All
</Directory>
If I go to hanslammerts.mine.nu/zm/, I do get the ZM page, and I can configure things.
I can't get any live stream or stills, though. In IE I get a placeholder, and if I look at the properties of that thing, it says
http://hanslammerts.mine.nu/cgi-bin/nph-zms?mode=single&monitor=4&scale=100&rand=1380742430&1380744057318
But I thought I told the primary Apache instance to proxy /cgi-bin ?
There must be something wrong in my configuration, but I don't see it.
Anyone out there that has done this trick before ?
I know my setup is tricky, and if I would make Vulcan the primary machine it would all be a lot easier, but Vulcan is the slower one....
Any suggestions are more than welcome.
Thank you,
Hans
