Hi!
Where can I find updated build instructions for Ubuntu Server 64 bit, version 12.04.3 LTS?
I am looking to install ZM with ffmpeg and x.264.
Have anybode done this sucessfully?
Thanks in advance for any tips!
Updated build instructions for Ubuntu Server 12.04.3
Re: Updated build instructions for Ubuntu Server 12.04.3
I have installed Zm 1.26.3 0n Ubuntu Server 12.04.03 32 bit without ffmpeg.
I'm going to do a clean reinstall in a few days with ffmpeg + H264 support.
To date the big problem was creating ffmpeg with H264, that took nearly 30 attempts to get the configure and paths right, but I now have it installed.
I am currently writing up my build steps. For 1.26.3 install I started with info from two sources:
https://github.com/ZoneMinder/ZoneMinder
http://pastebin.com/HPXwXTRU
Thanks, codabiz.
Did you manage to install it with ffmpeg + h.264? Do you have a step by step guide for doing this?
Thanks.
Thanks.
If you geht it running with ffmpeg, i also would like to read your builing steps. I tried the guide Form ffmpeg, but i made the mistake Tod do all AS root... but wie need Tod read carefully what is with user and with sudo . Otherwise you will have ffmpeg in /root/... not in /bin/...
Maybe you can write it in the wiki, because there is everything outdated.
