When i start SuSE Linux 9.0, my processor use is just under 20 percent. I`ve noticed that when i logon on to ZoneMinder the processor-use increases with 20%. Then when i start the running, the processor use hangs allmost at 90%.
Does anybody knows if this is normall or that my setup is not quiet good.
My system is a P3 @ 500 MHZ --with- +- 500 mb memory
Why is my processor use so high?
Re: Why is my processor use so high?
the system I'm configuring now has Celeron 566mhz, 150mb memory; 1 camera connected via Pinnocle PC TV at 4 fps; it uses 10% cpu while analizing and about 90% while capturing
linux distrib is SuSE 8.2
Well then i`m not the only one...
Could more of you send your specs and your rendering. I hope that its just
a configuration setting wich could couse this slowlyness.
Thanks in advance,
Sido
Thanks in advance,
Sido
- zoneminder
- Site Admin
- Contact:
There are a number of reasons why processor loads can be. To figure out exactly what is causing it in your circumstances requires a bit of expermentation.
The main causes are.
1. Using a video palette other than greyscale or RGB24. This can cause a relatively minor performace hit, though still significant. Although some cameras and cards require using planar palettes ZM currently doesn't support this format internally (yet) and each frame is converted to an RGB representation prior to processing. Unless you have compelling reasons for using YUV or reduced RGB type palettes such as hitting USB transfer limits I would experiment to see if RGB24 or greyscale is quicker. Put your monitors into 'Monitor' mode so that only the capture daemons are running and monitor the process load of these (the 'zmc' processes) using top. Try it with various palettes to see if it makes a difference.
2. Big image sizes. A image of 640x480 requires at least four times the processing of a 320x240 image. Experiment with different sizes to see what effect it may have. Sometimes a large image is just two interlaced smaller frames so has no real benefit anyway.
3. Capture frame rates. Unless there's a compelling reason in your case there is often little benefit in running cameras at 25fps when 5-10fps would often get you results just as good. Try changing your monitor settings to limit your cameras to lower frames rates. You can still configure ZM to ignore these limits and capture as fast as possible when an event is detected.
4. Run function. Obviously running in Record or Mocord modes or in Modect with lots of events generates a lot of DB and file activity and so CPU and load will increase.
5. Basic default detection zones. By default when a camera is added one detection zone is added which covers the whole image with a default set of parameters. If you camera covers a view in which various regions are unlikely to generate a valid alarm (ie the sky) then I would experiment with reducing the zone sizes or adding inactive zones to blank out areas you don't want to monitor. Additionally the actual settings of the zone themselves may not be optimal. When doing motion detection the number of changed pixels above a threshold is examined, then this is filter, then contiguous regions are calculated to see if an alarm is generated. If any maximum or minimum threshold is exceeded according to your zone settings at any time the calculation stops. If your settings always result in the calculations going through to the last stage before being failed then additional CPU time is used unnecessarily. Make sure your maximum and minimumzone thresholds are set to sensible values and experiment by switching RECORD_EVENT_STATS on and seeing what the actual values of alarmed pixels etc are during sample events.
6. Optimise your settings. After you've got some settings you're happy with then switching off RECORD_EVENT_STATS will prevent the statistics being written to the database which saves some time. Other settings which might make a difference are ZM_FAST_RGB_DIFFS, ZM_OPT_FRAME_SERVER and the JPEG_xxx_QUALITY ones.
Cheers,
Phil
Cheers,
Phil
