All went well installing Zone Minder 1.21.0 on RH 7.3 until - trying to access from the browser for the first time.
I receive the following error:
Warning: Client does not support authentication protocol requested by server; consider upgrading MySQL client in /var/www/html/zm/zm_db.php on line 21
Could not connect to database: Client does not support authentication protocol requested by server; consider upgrading MySQL client
I have search the forums, but have not been able to find any hints to help with this issue.
Anything help that you can provide would be greatly appreciated.
Thank you in advance,
Karl
Here is the MySQL version I have installed:
MySQL-server-4.1.11-0
MySQL-devel-4.1.11-0
MySQL-shared-4.1.11-0
MySQL-client-4.1.11-0
MySQL-shared-compat-4.1.11-0
I have the following PHP versions installed:
php-mysql-4.1.2-7.3.6
asp2php-0.76.2-1
php-4.1.2-7.3.6
php-ldap-4.1.2-7.3.6
asp2php-gtk-0.76.2-1
php-imap-4.1.2-7.3.6
Apache:
apache-1.3.27-4
- zoneminder
- Site Admin
- Contact:
Thank you Phil,
You are right, it is an issue with authentication to MySQL.
It is an issue with how ZM is trying to login / authenticate itself with MySQL. I can't seem to find what code / script specifies the login credentials. My preference would be to see if it can be changed there rather than start MySQL 4.1.1 with --old-passwords option.
Thank you for getting me a little further down the path.
Karl
Karl
- zoneminder
- Site Admin
- Contact:
