zm
cnr0616
zm
Post by cnr0616 »
cordel
Post by cordel »
Hi Craig,
One of two things.
The Defualt login is admin with the password admin.
If the first is not your problem then turn off or set to passive selinux which you can find in the Applications button --> system settings --> Security level
under the SELinux tab just uncheck enforcing current.
Let me know if this helps or not.
Cheers,
Cordel
