I'm totaly new here and tried to setup zoneminder on a ubuntu 13.10 server.
Now I got some problems faceing the live output, I used this manual to setup http://www.zoneminder.com/wiki/index.ph ... e_easy_way and this to fit with apache2 version http://www.zoneminder.com/wiki/index.ph ... on_changes
All I got now is the outupt shown in the attachment.
btw is there any change to get rid of this annoying java warning?
No live video
No live video
- ZM.jpg (18.46 KiB) Viewed 2398 times
Re: No live video
Did you get a resolution? IF so, please share?
Re: No live video
What do you mean with a resolution? Its a usual VGA 640x480 cam. If you mean a sulution, no I dont have one jet.
Re: No live video
Do you have cambazola installed?
Re: No live video
Jipp cambozola is installed, this is why I get the Java warning, something like: this instance will not be supported anymore in the future.PacoLM wrote:Do you have cambazola installed?
