Video capturing but no image feed on the monitors
lukeyduke
Post by lukeyduke »
Dear All,
I have recently done a clean install of 1.26.5. I have added two cameras. I think the configuration is correct as the video is recording. I can export it as a video or stills and this is working fine. However, I cannot see anything on the monitor or montage tabs.
The logs show the video is capturing but I am also getting errors.
2013-12-19 19:06:49.688296 web_php 6182 ERR socket_sendto( /tmp/zm/zms-492532s.sock ) failed: No such file or directory includes/functions.php 2344
2013-12-19 19:06:43.982570 undef 9144 ERR Config mismatch, expected 218 items, read 215. Try running 'zmupdate.pl -f' to reload config. zm_config.cpp 259
2013-12-19 19:06:43.838241 undef 9141 ERR Config mismatch, expected 218 items, read 215. Try running 'zmupdate.pl -f' to reload config. zm_config.cpp 259
2013-12-19 19:06:43.688282 undef 9138 ERR Config mismatch, expected 218 items, read 215. Try running 'zmupdate.pl -f' to reload config. zm_config.cpp 259
2013-12-19 19:06:23.186433 zmc_m2 8542 INF MainDoor: 15000 - Capturing at 15.15 fps zm_monitor.cpp 2783
2013-12-19 19:05:58.101364 zma_m1 9061 INF Cailyn: 3000 - Processing at 15.15 fps zm_monitor.cpp 1147
I have tried running 'zmupdate.pl -f' to no avail. I think it is something simple but I cannot get it to work.
Any help would be greatly appreciated. Apologies in advance if I am being an imbecile.
Regards,
Luke
Re: Video capturing but no image feed on the monitors
Linux distro and version?
Bill
lukeyduke
Post by lukeyduke »
Hi Bill,
Thanks for answering. I am running version 1.26.5 on Centos 6.5. When I do a clean install of 1.25.0 everything is fine.
Regards,
Luke
Sorry, I do not know Centos. I could, however, take a guess that the newest version used the same Apache version that Ubuntu 13.10 uses. I've not been able to get ZM working on 13.10...has the same results you have reported.
Bill
chippy99
Post by chippy99 »
I had a similar problem when I upgraded from 1.26.4 to 1.26.5 and it complained about having 126 records in Config instead of 125.
I cured it by deleting the Config table and then hacking the zm_create.sql and only only leaving in the lines that created the Config table and the lines at the end of the file that populate it with data.
No idea why I had to do this but it fixed it so maybe worth a try, backup your database first though.
If you want a copy of the sql file I used and maybe a more detailed explanation then feel free to P.M. me
lukeyduke
Post by lukeyduke »
Thanks Bill and chippy99,
I have managed to get 1.25.1 going without any errors or glitches. I am tempted to leave it alone now. I'll will try again in a few months when I have more time. Hopefully an update will be out by then. :D
Thanks for your help.
Regards,
Luke
