Thanks to Lubomir Rintel's work on reverse engineering the windows driver there's already a preliminary driver/module available to compile and use this capture pen with zoneminder for example! So far only NTSC capture through the RCA connector is supported, but PAL will already "work" with some glitches.
I'm new to Linux so I had a hard time making this work. I'm reproducing here the steps I took so that every other linux challenged person
As I'm a new forum user I can't post off-site URL's
Starting with a Ubuntu 12.04 server install, update to the latest kernel.
You can browse kernel d0t ubuntu d0t com/~kernel-ppa/mainline to check the latest version and update links accordingly. At the time of this writing it's 3.11 rc4.
If you have a 32bit install:
wget -c kernel d0t ubuntu d0t com /~kernel-ppa/mainline/v3.11-rc4-saucy/linux-headers-3.11.0-031100rc4_3.11.0-031100rc4.201308041735_all.deb
wget -c kernel d0t ubuntu d0t com /~kernel-ppa/mainline/v3.11-rc4-saucy/linux-headers-3.11.0-031100rc4-generic_3.11.0-031100rc4.201308041735_i386.deb
wget -c kernel d0t ubuntu d0t com /~kernel-ppa/mainline/v3.11-rc4-saucy/linux-image-3.11.0-031100rc4-generic_3.11.0-031100rc4.201308041735_i386.deb
sudo dpkg -i *.deb
wget -c kernel d0t ubuntu d0t com /~kernel-ppa/mainline/v3.11-rc4-saucy/linux-headers-3.11.0-031100rc4-generic_3.11.0-031100rc4.201308041735_amd64.deb
wget -c kernel d0t ubuntu d0t com /~kernel-ppa/mainline/v3.11-rc4-saucy/linux-image-3.11.0-031100rc4-generic_3.11.0-031100rc4.201308041735_amd64.deb
sudo dpkg -i *.deb
shutdown -r now
mkdir usbtv
cd usbtv
wget git d0t kernel d0t org/cgit/linux/kernel/git/torvalds/linux.git/plain/drivers/media/usb/usbtv/Kconfig
wget git d0t kernel d0t org/cgit/linux/kernel/git/torvalds/linux.git/plain/drivers/media/usb/usbtv/Makefile
wget git d0t kernel d0t org/cgit/linux/kernel/git/torvalds/linux.git/plain/drivers/media/usb/usbtv/usbtv.c
apt-get install make
apt-get install gcc
nano Makefile
obj-m += usbtv.o
KVERSION = $(shell uname -r)
all:
make -C /lib/modules/$(KVERSION)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(KVERSION)/build M=$(PWD) clean
Press Ctrl+O and [Enter] to output changes to the file. Ctrl+X to exit nano text editor.
Going super user here might be needed.
sudo su
make
copy .ko to modules dir
mkdir -p /lib/modules/$(uname -r)/kernel/drivers/media/usb/usbtv
cp usbtv.ko /lib/modules/$(uname -r)/kernel/drivers/media/usb/usbtv
depmod -a
modprobe usbtv
list loaded modules:
lsmod
Check if there's a new /dev/video folder:
ls /dev/
Other observations:
If you have more than one capture device, like a bttv based capture card you have to define/fixate it's /dev/videoX path otherwise a reboot will change this in an arbitrary manner and you'll have to reconfigure the ZM device paths of your capture devices.
To see if you can pass this parameter to your capture card run
modinfo bttv
If it has the following parameter listed:
parm: video_nr:video device number (array of int)
For example in a bttv card
options bttv video_nr=1
Another way is introducing in ZM the "Device Path" by its link inside the /dev/v4l/ folder instead of /dev/video#
udevadm info -n /dev/video0 -qall | grep DEVLINKS
E: DEVLINKS=/dev/v4l/by-id/usb-fushicai_usbtv007_300000000002-video-index0 /dev/v4l/by-path/pci-0000:00:02.2-usb-0:2:1.0-video-index0
This worked with the Easycap's device "by-id" link. It's useful since the driver still doesn't have a video_nr parameter at this stage. I had mixed results with the capture cards, it's best to just use the video_nr parameter.
Next steps:
Get this working in Android
