Used ZM years ago and am coming back to it again.
I want to trigger an x10 event when a ZM monitor goes into alarm, problem is that I am running heyu on the same machine so it has my x10 CM11a tied up, so I decided to try to just have ZM trigger another script where I'll run a heyu command to trigger my x10 event.
I found on the FAQ page there is a script to do exactly this:
http://www.zoneminder.com/wiki/index.ph ... n_alarm.3F
#!/usr/bin/perl -w
use strict;
use ZoneMinder;
$| = 1;
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)";
my @monitors;
push( @monitors, $monitor );
while( 1 )
next if ( !zmMemVerify( $monitor ) );
# Do your stuff here
sleep( 1 );
$ ./zmtest.pl
Undefined subroutine &main::zmDbgInit called at ./zmtest.pl line 9.
Tom
