I've searched and searched, but haven't figured out why I'm getting the following error.. I can view streams via mjpeg fine, but when I switch to MPEG, I get these socket errors.. .Any ideas? Thanks!
2014-01-29 20:23:00.449919 web_js 13563 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-968948s.sock ) failed: Connection refused - checkStreamForErrors() ?view=watch
2014-01-29 20:23:00.385782 web_php 13563 ERR socket_sendto( /tmp/zm/zms-968948s.sock ) failed: Connection refused /usr/local/share/zoneminder/www/includes/functions.php
Getting socket_sendto Connection Refused Error
Re: Getting socket_sendto Connection Refused Error
Finally found something that seems to have fixed it..
In the images tab there is a section for MPEG_LIVE_FORMAT, remove the SWF from there and leave it blank.... That fixed it for me.. Still going to play with it some more... but at least I no longer get the socket errors
I am having the same problem, but the workaround posted above does nothing to improve my situation. I actually cannot observe any consequence of this message other than the fact that it's filling my log files with error messages.
