Zoneminder RPM & SRPMS for Red Hat & CentOS 6
- knight-of-ni
Re: Zoneminder RPM & SRPMS for Red Hat & CentOS 6
* BUMP *
ZoneMinder 1.27.0 has been released.
Please fix the links in the subject header. Unable to download anything. Thank you.
- knight-of-ni
They all work for me. From what country does your ip address originate from? My firewall is set to block traffic from certain countries associated with spam and other unwanted traffic. I could make an exception if you tell me where you are from.6ax wrote:Please fix the links in the subject header. Unable to download anything. Thank you.
hey knnniggett
thanks for posting such detailled instructions on installing ZM on CentOS...
I am trying to get it running on CentOS 6.5, followed the steps to the letter and using 1.27 but when I try to start the ZM service, I get a [FAILED] with nothing else...
How can I troubleshoot this? I tried with:
service zoneminder start
and /etc/init.d/zoneminder start
but both fails.
I am totally new to CentOS/RH and being used to slackware, I would generally know where to look but on CentOS I am a little lost....
Cheers!
but both fails.
Cheers!
- knight-of-ni
Make sure mysql is runnning.
If you have an existing database, it will do that if you have not successfully run "sudo zmupdate.pl" first.
If your database is new, make sure you have followed the steps to create it.
OK.. you were right with the DB update... now ZM starts, but I get LOTS of errors, and the live feed doesnt work.
From the logs:
[code]2014-03-29 11:45:31.959085 web_js 20917 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:31.935623 web_php 20921 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:45:25.946457 web_js 20916 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:25.923431 web_php 20918 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:45:19.937301 web_js 20921 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:19.911934 web_php 20920 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:45:15.533157 zma_m1 23157 INF Monitor-1: 2000 - Processing at 30.30 fps /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_monitor.cpp
2014-03-29 11:45:13.954908 zmc_m1 23127 INF Monitor-1: 2000 - Capturing at 30.30 fps /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_monitor.cpp
2014-03-29 11:45:13.925335 web_js 20918 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:13.901207 web_php 20923 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:45:07.911325 web_js 20920 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:07.889643 web_php 20919 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:45:01.905122 web_js 20923 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:45:01.877828 web_php 20920 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:44:55.891151 web_js 20918 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:44:55.866389 web_php 20923 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:44:49.875347 web_js 20920 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2014-03-29 11:44:49.852597 web_php 20919 ERR socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
2014-03-29 11:44:43.857427 web_js 20923 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-770548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch[/code]
/var/run/zm exists and apache has all right into it (rwx)
The source is in GREEN but the LOG is in RED.
DO you have an idea whats not right?
Thanks!!!
From the logs:
Thanks!!!
- knight-of-ni
Either your Apache config is not right or your are running at too high a frame rate for your hardware.
[quote]Either your Apache config is not right or your are running at too high a frame rate for your hardware.[/quote]
Apache's config was erroneous IMO.. I changed a few things and for a month or so, everything is fine now.
Now that its "working" I'd like to have ZM start monitoring and stop monitoring based on a schedule... 99% of the events are simpy me when I pass in front of the camera..
I tried searching in ZM's config and options, to no avail..
Same on the internet. I'd like ZM to start monitoring when I leave for work and stop when I come back. Should be simple enough??? The only cheap way I found would be to have CRON send
[code]service zoneminder stop[/code] or [code]zmpkg.pl stop[/code] to stop it at a specific time, and
[code]service zoneminder start[/code] or [code]zmpkg.pl start[/code] to start it at a specific time...
Is there a function in ZM for this??
Thanks!
Thanks!
Hi all,
My 1.26.4 was giving me troubles and I couldn't figure out what was going on. So I decided to start a clean reinstall.
Just followed the instructions to install 1.27.0-1.el6.i686 but yum reports dependency errors. Don't know how to deal with this, but this is the relevant output:
Any leads how to proceed? Thanks.
--> Finished Dependency Resolution
Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686)
Requires: libswscale.so.2
Requires: libavformat.so.53(LIBAVFORMAT_53)
Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge)
Requires: libmodplug.so.0
Requires: libupnp.so.3
Requires: vlc-core
Requires: libswscale.so.2(LIBSWSCALE_2)
Requires: libavutil.so.51
Requires: libebml.so.2
Requires: libavutil.so.51(LIBAVUTIL_51)
Requires: libavcodec.so.53
Requires: libavdevice.so.53
Requires: libmatroska.so.2
Requires: libthreadutil.so.2
Requires: libavcodec.so.53(LIBAVCODEC_53)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Good luck with that!
My experience has shown that it is caused by mixing software from different repos...
CentOS really HATES that!
Repos are cool but not properly configured, dangerous,
My own centos server will need restart fron scratch because of that same reason..
- knight-of-ni
First, follow the instructions in the first post of this thread that describes how to set up all three repos if you have not already. Don't skip any steps!swiftflic wrote:Hi all,
Just followed the instructions to install 1.27.0-1.el6.i686 but yum reports dependency errors. Don't know how to deal with this, but this is the relevant output:Any leads how to proceed? Thanks.Code: Select all
--> Finished Dependency Resolution Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libswscale.so.2 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavformat.so.53(LIBAVFORMAT_53) Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge) Requires: libmodplug.so.0 Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge) Requires: libupnp.so.3 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavformat.so.53 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: vlc-core Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libswscale.so.2(LIBSWSCALE_2) Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavutil.so.51 Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge) Requires: libebml.so.2 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavutil.so.51(LIBAVUTIL_51) Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavcodec.so.53 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavdevice.so.53 Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge) Requires: libmatroska.so.2 Error: Package: vlc-1.1.13-1.el6.rf.i686 (rpmforge) Requires: libthreadutil.so.2 Error: Package: zoneminder-1.27.0-1.el6.i686 (/zoneminder-1.27.0-1.el6.i686) Requires: libavcodec.so.53(LIBAVCODEC_53) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest
Second, follow the instructions under the troubleshooting section for resolving the conflicts.
Basically, you need to remove the vlc and ffmpeg packages from rpmforge already on your system and then let yum grab the newer versions of these packages from the rpmfusion repo.
Thanks for the feedback, I tried to follow the first post. But apparently I forgot to enable the rpmfusion-free-updates repository, when setting priorities. I was actually able to install after that!
But now after a clean install my log looks like this:
2014-06-27 02:24:57.309210 zmpkg 6176 ERR Unable to run "sudo -u [username] /usr/bin/zmdc.pl startup", output is "Starting server" zmpkg.pl
2014-06-27 02:24:57.296370 zmdc 6184 FAT Can't connect: No such file or directory zmdc.pl
2014-06-27 02:24:49.647070 zmdc 6185 FAT Can't bind: Permission denied zmdc.pl
2014-06-27 02:24:47.300450 zmdc 6185 INF Server starting at 14/06/27 02:24:47 zmdc.pl
2014-06-27 02:24:46.609100 zmpkg 6176 INF Command: start zmpkg.pl
2014-06-27 02:24:21.344520 zmpkg 6139 ERR Unable to run "sudo -u [username] /usr/bin/zmdc.pl check", output is "" zmpkg.pl
2014-06-27 02:24:21.213780 zmpkg 6139 INF Command: start zmpkg.pl
2014-06-27 02:21:47.004700 zmpkg 6053 ERR Unable to run "sudo -u [username] /usr/bin/zmdc.pl check", output is "" zmpkg.pl
2014-06-27 02:21:46.837550 zmpkg 6053 INF Command: start zmpkg.pl
- knight-of-ni
"Can't Bind" means that zoneminder was unable to create a socket. This can be caused by file/folder permissions, attempting to start a second instance of zoneminder, and/or stale files lying around from a previous installation.
However, looking at the big picture, you've managed to get your system into an unknown state.
This could easily turn into a game of whack-a-mole where you solve one problem only for another to pop-up.
The best thing to do would be to get your system back to a default, clean state and then start over.
Well it did cost me a night of decent sleep, but I worked it out in the end (it was a permissions issue). It is running, but in the interface it tells me it is 1.26.5?
Also live video to my browser and phone is not working. I get the following message: Does anyone have experience with this? I also don't see the image when I want to edit a zone. It seems that /var/cache/zoneminder/images/Zones1.jpg is not created. How can I debug that?
Unable to load monitor id -1 for streaming /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_stream.cpp
...this system is really starting to piss me off. Every version update I spend 2 weeks to solve all the issues. It is still not running correctly over here and now I even lost my 'log' butten in the web interface.
